5 members (dt235sd, Hush, Rich'sToys, Toadwart, 1 invisible), 296 guests, and 3 robots.
Topics128,087
Posts1,055,999
Members48,430
#1499731 05/06/2023 4:12 PM
While working on my "new" 41 AK that was suppose to have been restored. I noticed that the front springs are different - driver side has 7 leafs and the passenger side 8. Other than different ride quality what other problems will this cause? I have noticed that parts vendors all sell only pairs. Is it possible to get just one?
Which one do you want to buy? The 8 leaf? The 7 leaf?
Buy a brand new set of two so the car sits level. Springs should always be replaced in pairs.
I'm wondering if the frame is twisted and the idiot removed one leaf to get the vehicle to appear level.
1950 Chevrolet 3100 (Ol' Roy)
Maybe the passenger weighed considerably more than the driver???
In looking at springs for my 58 and my daughter's jeep, different vendors sell spring with notionally the same load but different numbers of leaves.
It could easily be a case where one spring was damaged and they had a replacement made for just that one.
That doesn't really play with the claim of it being "restored", but we have seen a lot of sketchy work hidden under a "restoration" before.
I would be inclined to bite the bullet and replace them both with a matched pair of known correct ones.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
How does it set, level? How does it ride? Does it set level with driver in it? Removing one leaf isn't that hard, if it's the smallest of the stack, it won't change much of anything except the 1/4" or more hight.
The truck came with 7 Lvs, load rate 775lbs, spring rate 260lbs and free arch 4”. P/N 599316, SRI #120-130. When you start adding or subtracting a leaf, you change the spring rate, load rate and maybe the arch. Buy a brand-new set. I would check the frame too.
Is the 8Lvs a two-stage spring?
ronsway #1500702 05/13/2023 10:14 PM
ronsway You know our local spring shop just adjusts those spring leaves cold with their press. They can easily adjust ride hight,you can too even rusty leaves .
