2 members (Rich'sToys, klhansen), 125 guests, and 1 robot.
Topics128,196
Posts1,057,388
Members48,471
#150013 01/06/2007 2:06 PM
i cant get my pto engaged in my 65 C60. there is 2 levers in the cab of the truck and nothing was happening, so i crawled under and found a loose connection from the lever end and the braket that attaches to the pto. I remove said bolt and tried to engage it by hand from under the truck....nada but gear grinding....am i missing something? granted i am not real familiar with pto's and such, but it looks pretty straight forward and i am feeling retarded right now.
#150014 01/06/2007 2:15 PM
I'm no expert on PTO's but I engage the clutch on my fire truck before engaging the PTO and it works fine. Try hooking up the lever and using the clutch. Good Luck!
1949 Chevy 6400
1931 Chevy Firetruck
#150015 01/06/2007 3:21 PM
Yes he is correct with the engine running you will not be able to engage the PTO with out depressing the clutch,
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
#150016 01/06/2007 4:48 PM
If i wasnt absolutely certain of what I was putting into gear, I wouldnt be engaging linkages while i'm under a running truck... eek oh, and it's "developmentally challenged".... unless you are referring to timing.
Another quality post.
Real Trucks Rattle
#150017 01/06/2007 6:48 PM
i knew what the lever was for Rusty Rod....the problem was with the lever attached it wouldnt move the bracket enough to engage it at all, which it why i went under it (with my brother in the cab depressing the clutch)
#150018 01/06/2007 6:55 PM
if it won't go into drive with the clutch depressed it's hooped - pretty common for folks to forget they've got it engaged and drive on home - the PTO gearing isn't set up for highway speeds
time to open'er up and clean out the bits eek
#150019 01/06/2007 7:21 PM
The PTO on my '56 dump is kinda picky about when it wants to engage.
I found that pulling the PTO lever into gear as I slowly engage the clutch works well. Spins up the gears, but it's still loose enough for everything to mesh & it pops right in. Altho, my PTO lever is pretty tight & only moves about an inch from engaged to disengaged.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
#150020 01/06/2007 7:38 PM
My lever had about 8-10inches of travel, way more than i thought it needed.
#150021 01/06/2007 11:16 PM
IF your PTO has a lever on a side plate then it was made for a cable control. This lever, about 2.5-3" long will travel approx. 25 degrees at the end where the cable attaches. LEVER control PTO's used an eye bolt and these come out through the end of the cast housing. They have about 1" of travel in and out. This is pretty much true regardless of brand (Muncie or Chelsea)on the older units and whether it is a single gear or a double gear PTO. If you have a lot of handle travel if may only mean that your control lever is excessively long. Too long a handle cause unnecessay vibration and gear wear. If yours has the little side mounted lever(above) then I would most certainly change it to a cable operation.
When engaged a PTO should not make any noise. If it whines it needs shim gaskets and if it rattles then it needs to have thinner gasket(s). Gaskets come from .010 to .030 and spacers come from .060 to .375. Nearly all the old dump trucks with basic 4 & 5 speed transmissions used single gear PTO, i.e., the unit had one gear that slides on and off the driving gear inside the tranny. These transmissions had only six bolt opening(s) and were on the side(s).
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#150022 01/07/2007 12:17 PM
What happened to me on my '48 2t. was that the cable control slipped in the bracket underneath the truck, so pulling and pushing the dash knob just moved the slack in the whole cable not the lever on the trans. It was hard to tell looking underneath with all the gunk.
#150023 01/07/2007 1:57 PM
As long as were talking PTO and hoists, tell me what these knobs do. I think the two on the left are for the PTO and hoist? The left is the PTO and I believe the one next to it is the hoist.
<img src="http://i142.photo...cket - Video and Image Hosting">
My Trucks
Stuff I Collect
#150024 01/07/2007 6:42 PM
One or the other is, thats for sure. The one that goes to the valve on the pump is likely a Williams piston pump. Could be S/A or D/A depending on the hoist. I'd bet it is an old grain truck with a scissor hoist, correct?
Dave
#150025 01/07/2007 8:43 PM
Not sure, it has one massive cylinder with a transmission driven pump. The knob on the left is a cable that runs down to the PTO. The truck was used to haul mail across South Dakota. It has a flat bed on it right now, sort of, a cow could fall through it and never touch anything!!
My Trucks
Stuff I Collect
#150026 01/07/2007 11:03 PM
I pretty clear on what you have.
" a cow could fall through it and never touch anything!!"
I'd stay away from the cattle hauling business if I were you. grin
Dave
#150027 01/08/2007 3:31 AM
Hey Dave, can I convert my lever system to a cable system? Or would it be too much to push/pull for a cable?
#150028 01/08/2007 4:34 AM
I see that you said that it was grinding pushing in the clutch put the truck in gear then the PTO take the truck back out of gear and let out the clutch. Sounds to me like maybe your clutch is sticking to the flywheel. Or the piolet bushing is tite.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#150029 01/08/2007 5:04 AM
badtexasz28: I don't know what type PTO you currently have. Some cable shift PTO's have a floor lever attached to the shift arm lever so w/o a description or photo of what you have I cannot say if you can install a cable shift or not. This may sound confusing to you but I don't know any other way to decribe it. If you have the eye bolt straight push/pull shifter then you cannot operate it with a cable. The cable needs the advantage of the small lever to operate the shift rod.
HevyHauler may be correct about the clutch sticking. Can you shift the transmission in/out of gear OK? If not then that is a likely problem.
Dave
#150030 01/08/2007 3:53 PM
I can shift it ok most of the time, every once in awhile i have trouble getting it into 1st gear. As far as the eye bolt you referred to, my setup has two levers next to the shifter. The lever that engages the PTO goes through the floor and connects via a small 2" bracket to a smaller (about 2.5-3" long)lever coming off of the PTO itself. The other lever is connected to a log rod which goes back to the hydraulic pump. I will try and get a couple of pictures unless you dont need them after the above description provided by a newbie big bolter....lol
#150031 01/08/2007 6:31 PM
OK badtexasz28, I now know what you have and yes, you can eliminate the PTO floor lever and install a cable to connect to the small shift arm on the PTO cover plate. Buy a vinyle wrapped 10' push/pull cable with the PTO cable retaining bracket and also get a bowdin pin for the shift arm. The knob end may be installed in a bracket under the dash as in a photo posted above or you can drill a hole in the lower dash. I like them on the floor at the door sill area so you can stand outside the cab and control the hoist as you watch it dump.
Dave
#150032 01/10/2007 1:03 AM
Yeah, so I got the PTO a'turnin'....but no worky worky. I am wondering ifthe pump is shot. Where is a good source for pumps and hydraulic related stuff?
#150033 01/10/2007 1:10 AM
sorry it posted twice
#150034 01/10/2007 1:21 AM
badtexasz28 See if you can find a tag with a brand and model number. Or it may have a stamped number somewhere. A casting number won't do you any good a tag or a stamping. Also check the shaft for sheared keys. Be shure the shaft is realy turning the pump.
user
#150035 01/10/2007 3:09 AM
R Online: Content
If your PTO is working, but the bed won't lift, try moving the other lever back and forth slightly. Sometimes it needs to be in a certain "sweet spot" in order for it to work.
Also, make sure your hoist has fluid in it. This can sometimes be difficult with the bed down, but can be done. This has also been covered in previous posts.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
