| | | Forums66 Topics128,066 Posts1,055,874 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | While working on my "new" 41 AK that was suppose to have been restored. I noticed that the front springs are different - driver side has 7 leafs and the passenger side 8. Other than different ride quality what other problems will this cause? I have noticed that parts vendors all sell only pairs. Is it possible to get just one? | | | | | Joined: Oct 2021 Posts: 6,771 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,771 | Which one do you want to buy? The 8 leaf? The 7 leaf?
Buy a brand new set of two so the car sits level. Springs should always be replaced in pairs.
I'm wondering if the frame is twisted and the idiot removed one leaf to get the vehicle to appear level.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jan 2022 Posts: 2,446 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,446 | Maybe the passenger weighed considerably more than the driver???
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | In looking at springs for my 58 and my daughter's jeep, different vendors sell spring with notionally the same load but different numbers of leaves.
It could easily be a case where one spring was damaged and they had a replacement made for just that one.
That doesn't really play with the claim of it being "restored", but we have seen a lot of sketchy work hidden under a "restoration" before.
I would be inclined to bite the bullet and replace them both with a matched pair of known correct ones. | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | How does it set, level? How does it ride? Does it set level with driver in it? Removing one leaf isn't that hard, if it's the smallest of the stack, it won't change much of anything except the 1/4" or more hight. | | | | | Joined: Jan 2022 Posts: 197 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 197 | The truck came with 7 Lvs, load rate 775lbs, spring rate 260lbs and free arch 4”. P/N 599316, SRI #120-130. When you start adding or subtracting a leaf, you change the spring rate, load rate and maybe the arch. Buy a brand-new set. I would check the frame too. Is the 8Lvs a two-stage spring? | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | ronsway You know our local spring shop just adjusts those spring leaves cold with their press. They can easily adjust ride hight,you can too even rusty leaves . | | |
