Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (CuzzFuzz, baldeagle, Rusty Rod), 37 guests, and 1 robot.
Topics128,003
Posts1,055,244
Members48,418
#1499595 05/05/2023 3:23 PM
Just curious about a mark on the flywheel on the 216. I know that the timing is to be set when the "bb" on the flywheel is behind the pointer in the bell housing. That is a given. But, a couple degrees before the "bb", there is a triangle mark. What is the significance of that mark? I can't find any mention of it in the factory shop manual, and it has my curiosity up.
OK here's the skinny re timing marks etc from Pre68Dave.
http://chev235guy.blogspot.com/search/label/Flywheel%20Timing%20Marks
1946 1/2-Ton Chevy
Ah, soo! Didn't know that the triangle was for cam timing purposes. Not something for me to obsess over. Thanks for educating me!
The triangle or the U/C mark on some flywheels is used for doing an "engine stopped" valve adjustment on solid lifter engines. The factory service manual specifies that six valves are adjusted with the indicator aligned with the pointer, then the engine is turned 360 degrees until the mark lines up again and the other six are adjusted. It's much more accurate than chasing a moving rocker arm with a wrench, a screwdriver, and a feeler gauge.
