| | | Forums66 Topics128,081 Posts1,055,959 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | This is an electric operated e-brake? I would think you would want a e-brake to be 100% manual? | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | It depends on your goal. I have looked at these a couple times.
They require power to engage or disengage, but if you engage it and cut power it will stay engaged. | | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | My Lexus RX has an electric operated e-brake. It engages the brake when you move it into park. There is an override switch you can use when stopped on a hill; I have never used that switch.
First time I encountered an electric e-brake was in Scotland when I rented a Vauxhall car. We got in the car and I started it up. Fran asked "What are you waiting for?" when I didn't start driving. "I can't find the brake - there is no lever or foot pedal!" Finally found the switch to disengage it - of course, it had some odd looking symbol on the switch which didn't help.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Put bucket seats iny panel and took the ebrake out of and old dodge colt and put it between the seats. Worked like a charm. Only had to buy a small ,"pulley" where cable came threw floor......just saying what I did. | | | | | Joined: Sep 2021 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 54 | The unit stays engaged with the power off, its wired directly to the battery, also, has the wiring so it will not release unless the ignition is on, so its a theft deterrant,
