0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#1498674 04/28/2023 11:11 PM
If your handbrake is useless like mine was, there is a simple upgrade to an E-Brake,
Called E-Stopp, a real easy fit unit
https://www.dropbox.com/s/2cu1mstkyvmfdmi/IMG_1459.MOV?dl=0
https://www.dropbox.com/s/146jmyjn67e43on/IMG_1461.MOV?dl=0
1959 Apache
""Rebuit everything and added a 440 Big Block"
Follow in the DITY
This is an electric operated e-brake? I would think you would want a e-brake to be 100% manual?
Dave from Northern Kentucky
My 54 3100
It depends on your goal. I have looked at these a couple times.
They require power to engage or disengage, but if you engage it and cut power it will stay engaged.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Insomniac
Insomniac
My Lexus RX has an electric operated e-brake. It engages the brake when you move it into park. There is an override switch you can use when stopped on a hill; I have never used that switch.
First time I encountered an electric e-brake was in Scotland when I rented a Vauxhall car. We got in the car and I started it up. Fran asked "What are you waiting for?" when I didn't start driving. "I can't find the brake - there is no lever or foot pedal!" Finally found the switch to disengage it - of course, it had some odd looking symbol on the switch which didn't help.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Put bucket seats iny panel and took the ebrake out of and old dodge colt and put it between the seats. Worked like a charm. Only had to buy a small ,"pulley" where cable came threw floor......just saying what I did.
The unit stays engaged with the power off, its wired directly to the battery, also, has the wiring so it will not release unless the ignition is on, so its a theft deterrant,
1959 Apache
Follow in the DITY
