2 members (Hotrod Lincoln, TexasA&M48Truck), 186 guests, and 1 robot.
Topics128,082
Posts1,055,964
Members48,430
#1498946 05/01/2023 2:44 PM
Does anyone know if my engine needs to be Top Dead Center when installing the flywheel. I read one place it does and another that it can only go on one way. Any tips are appreciated.
Thanks.
NC Scout 52-5
NC Scout 52-5,
Check out the install info for the flywheel Pg 1 and info for the flywheel Pg 2 from the 1954 Shop Manual. This is almost word for word the same as from the 1948-51 Shop manual, so should work for your '52, assuming your engine is a '52 235.
Extract screen shots are below.
Hope this helps you out! thumbs_up
Dan
Flywheel install page 1 1954 Chevrolet Truck Shop Manual.png (292.18 KB, 85 downloads)
Flywheel Install Pg 1
Flywheel install page 2 1954 Chevrolet Truck Shop Manual.png (31.05 KB, 84 downloads)
Flywheel Install Pg 2
~ Dan
1951 Chevy 3 window 3100
Dan,
Thanks for the quick response to my question.
Lenny
Scout
thumbs_up
~ Dan
So the answer to Lenny's question is NO.
The unevenly spaced dowels will only let you install it one way.
H Online: Content
Due to the spacing of the three dowel pins and the bolt holes, it's impossible to install the flywheel in the wrong position. It only bolts on one way regardless of the position of the pistons. BTW, the dowel pins are aligned exactly with the position of the three pairs of companion cylinders on the crankshaft. That can't be an accident!
