0 members (), 119 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
i have a 1948 chevy truck , with a 235 engine, and i have a small leak in the heater core, and i would like to ideally isolate the heater ( with piping or valve) to I can continue to drive my truck while taking my time in replacing or repairing the core. It is warm now in Montana, with no need for heat for 6 months plus. thanks
Last edited by Phak1; 04/27/2023 6:45 PM. Reason: Edited by Moderator:Corrected spelling directly to subject.
1948 3/4 ton Chevy Pickup
Remove one end of a heater hose from the heater and one end of the other heater hose from the waterpump. One hose will route from the waterpump back to the waterpump and the other will circle back to the heater.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
I have this valve on the hose going into the heater core that I use to open/close/regulate flow to the heater in lieu of the Ranco valve. It was around $20 at O'Reilly, and I use a $10 choke cable to work it from in the cab, but if all you want to do is isolate the heater, you don't need the cable. I don't know if there's risk of the system sucking air in through the leak or not.
https://media.fotki.com/2v2aS82LyxDubp.jpg
Or you can remove the hoses, loop one (or a short length of another hose) to the hose fittings on the water pump and thermostat housing to bypass the heater.
I assume you don't want to remove the hoses altogether and put plugs in place of the fittings on the water pump and thermostat housing since you intend to fix or replace the core to put it back in service.
I'd remove both hoses at the heater end and connect them together. That way you don't have to cut any hoses.
IF (big if) the hoses are different diameters, you should be able to find a 5/8" to 3/4" diameter adapter at your FLAPS.
H Online: Content
Just remove the hoses at the heater core and plug them. There's no need to circulate coolant through them at all- - - -the cooling system will work without any heater core flow.
Yep. Heater was an option you had to pay extra for. The trucks without a heater came with NPT plugs in the water pump holes.
My '39 Packard has a factory heater with a brass gate valve on the hot water outlet in the cylinder head. Open it in the winter and close it in the spring to keep anyhot water at all from warming up the cabin.
1950 Chevrolet 3100 (Ol' Roy)
Riding in the Passing Lane
Putting a valve in one of the hoses will not solve the leak problem. There still will be coolant in the heater with some pressure.
George
1972 Chevy c10 Cheyenne Super
