| | | Forums66 Topics128,117 Posts1,056,296 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Though I have 2 extra steering wheels, I wanted to first restore the one currently being used. Yesterday, removed it and installed one of the extra ones. Now, no horn! What did I do? forget the contact bushing? Messed up the horn button install? Removed the spare wheel and reinstalled the original wheel......still no honk. After going thru a couple hours of scratchin' my head, thought I would start looking at the dual horns and the relay setup that's mounted on the firewall. All looked as fine as expected, not being touched for a dozen years plus, but what caught my eye was the 3 terminals on the relay. Lots of crud build up. Maybe I should clean the terminals . Maybe I was desperate to find the culprit. Started with the wire coming from the steering column. Oh and did I mention, I forgot to disconnect the battery?
TOOT !!
My screwdriver touched a couple of the terminals and a horn or two and I was blasted. Cleaned the relay terminals and related wire terminals and all is good....for now.
So note to myself and others. When you are desperate to monkey around with the truck, consider looking at the various wiring harnesses with crud buildup, especially in the engine bay, etc. Oh, and disconnect the battery first.
Cheers
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | At least you did not buy an after-market one for $359.00 and 3 months late every time you turn a corner the horn blows.  BTW nice truck and back drop.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
