2 members (greenie-reddy, KEVINSKI), 116 guests, and 6 robots.
Topics128,266
Posts1,058,367
Members48,485
#1497240 04/19/2023 5:29 PM
1939 Chevy JD truck, 216, 3 speed transmission. I get clutch chatter in first gear sometimes when taking off, engine warm. Never in 2nd or 3rd. New clutch and pressure plate. Champ made an anti clutch chatter kit back in the day. Do any of you folks have input on this issue? The rear motor mounts have been replaced.
Rick
1939 Chevrolet Stake Truck
rickmg #1497243 04/19/2023 6:02 PM
I just replaced the front motor mount on mine hoping that will correct the 1st gear chatter and vibrations I was getting.
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
Did it work? Or do you know yet?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Just finishing up with all the winter repairs, I'll let you know.
rickmg #1497258 04/19/2023 9:11 PM
Adjusting the free travel on the clutch pedal fixed my 52 1/2 ton.
1952 Chevy Pickup Truck
rickmg #1497369 04/20/2023 6:22 PM
Did you have the flywheel refaced during the clutch replacement job?
rickmg #1497377 04/20/2023 7:58 PM
No Jerry I did not. I believe that may very well be my problem. Would I need to have both the flywheel and pressure plate refaced?
Rick
rickmg #1497391 04/20/2023 10:55 PM
If you only changed the clutch disc, you only did one third of the job. I always buy a rebuilt clutch and pressure plate, change the throwout bearing and the pilot bushing, and get the flywheel resurfaced. "Buy once- - - -cry once!"
rickmg #1497414 04/21/2023 2:26 AM
7
7 Offline
I did what HRL suggests, new clutch disk, pressure plate, pilot, throwout and refaced the flyweel, smooth as silk for the last 4-5 years.
rickmg #1497481 04/21/2023 3:07 PM
I replaced everything, but I didn't have the flywheel resurfaced.
Rick
rickmg #1497496 04/21/2023 4:50 PM
Might not be good news, sorry. but lIke has already been noted, that is most likely the cause.
You need that flywheel surface as flat as possible for the clutch disk to grab properly and/or have any longevity.
The more it slips(chatters) the more hot spots will be created.
1958 3100 Fleetside w/235 4spd
rickmg #1497511 04/21/2023 7:18 PM
When I take care of the flywheel, would I need to replace the pressure plate and clutch. About 1,000 miles on these items now and almost all of it highway driving.
Rick
rickmg #1497605 04/22/2023 1:50 PM
Rick
I wouldn't.
Look for any grease/oil and clean off of all surfaces and adjust it proper as you go back.
