4 members (RaNfLaS, Tyler Watts, DadsFirstPickup, Otto Skorzeny), 99 guests, and 1 robot.
Topics128,048
Posts1,055,663
#1492 02/29/2004 8:04 PM
I just took the gas tank out of my 53 because it was leaking. The fuel line went in to the bottom of the tank. Is this the right way to run the fuel line or should it be run to the tube that goes into the sending unit?
Friends don't let friends drive F**ds.
#1493 02/29/2004 9:30 PM
It's been a long time since I've been into one of them, but I believe the top line is a vent, which should be attached to a tube going to the outside, to allow air in as the tank drains, and vapors out. (Long before the days of carbon canisters and closed fuel systems!)
#1494 02/29/2004 9:44 PM
HOTROD LINCOLN is right or at least on my 51 chevy 3/4 ton it feeds out the bottom there should be a shut off there. If you take the sending unit out you will see what it does. good luck Bill
#1495 03/01/2004 3:36 AM
I have a 54 model apparently built in nov 53. It is a 1.5 ton and the gas feeds from the top of the tank. Im currently in process of replacing the lines. I was surprised by the set up figured it would be from the bottom like my 38. though one is behind the seat the other under it.
#1496 03/01/2004 3:52 AM
Thanks for the replies.
I guess it can be hooked up either way. I would think that it would be better from the top so that it would not suck up possible crud from the bottom.
