| | | Forums66 Topics128,053 Posts1,055,778 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 20 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 20 | Is it possible to use a 12V ring gear with 168 teeth on a 6V flywheel that had a 139 tooth ring gear? Though I am not able to accurately measure the diameter of the two flywheels where the ring gear fits, they appear to be the same at that point. I'm converting my 6V to 12V and have found that the 10" pressure plate for the 12V flywheel is too large for the old 1941 bell housing and binds at two reinforcement ribs in the top side of the bell housing. | | | | | Joined: May 2015 Posts: 11,040 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,040 | If you have a 12V ring gear off the flywheel, you could test fit it to the 6V flywheel. It shouldn't quite fit when cold and has to be heated to be installed.
The other option is to grind those reinforcements down a bit to clear. That might be an easier option rather than messing with changing ring gears. I'd suspect that would be a 15 minute job.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
