Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 179 guests, and 1 robot.
Topics128,299
Posts1,058,705
Members48,493
#1493775 03/24/2023 10:11 PM
Hi all,
just wanted to say hello and I did a pretty extensive write-up in the Stovebolt VFD section under Big Bolts.
Thanks for all of your info and input on here. It's been VERY useful in learning about these trucks from a bygone era.
1977 c65 VFD Water Truck
Great story and pix in "The House"
Stovebolt Volunteer Fire Department
Welcome to the Stovebolt communty! wave
I read your post in the VFD forum. Sounds like you already know a great deal about your truck and have a plan and end result established (noted in that post). thumbs_up
As a pointer or two in getting the most out our site, post your questions about specific tech topics you are seeking help with (like engine, drive line, etc.) in the individual forums in the The Shop Area as those apply to your truck just like the regular trucks.
You should also think about posting questions related to your "Big Bolt" sized truck in the Big Bolts forum as folks that spend most of their time in their probably have the best info that involves your size truck.
Looking forward to seeing more posts from you and we will do our best to try and help you out. shake
Dan
~ Dan
1951 Chevy 3 window 3100
Welcome to Stovebolt. Consider yourself at home. See you around the garage forums.
Welcome to the 'bolt. Another somewhat unique truck.
Another quality post.
Real Trucks Rattle
Big Bolt Forum Moderator
welcome to the site! Sweet looking truck!!
Mike
