| | | Forums66 Topics128,148 Posts1,056,811 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 163 | I found a set of decent traction tires for my 52 2 ton. I currently have 8.25 x 20, the tires I found are 9.00 x 20. Are other guys out there using 9.00's. Any issues I should be aware of. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I don't know about the AD 2ton but my TF 2ton has 10.00x22.5s came with 9.00x22.5s and they fit fine. | | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | Don't confuse the two different wheel sizes. There respictive numbers do not match. A 10.00x20 is bigger then a 10.00x22.5. A 10.00x20 is the same as a 11.00 22.5. The 22.5 wheels are the tubeless replacements for the tube type 20's. Jason, I think your truck will be fine steping up to the 9.00 tires...they will be a little taller making your speedometer a little off. Mike B  | | | | | Joined: Sep 2006 Posts: 38 Junior Member | | Junior Member Joined: Sep 2006 Posts: 38 | Jason, I recently swaped out the tired old 8.25x20 tires for a completed set of 9.00x20s on my '48 2 ton. They just fit the rims. Any wider and they wouldn't have been able to get the split rims back together. They are taller than the 8.25s and they sure fill up the front wheel wells, but I haven't had any problems with them rubbing the fenders. I originally wanted 8.25s but I got a very good deal on these 9.00s. I submited some pics of my truck to the Gallery, but havn't seen them yet. When it gets posted you'll be able to see they look good. Or I could email them to you. In short...they do work.
Rezman
Snapoff brand tools .................................. 1948 Chevy 6400 1949 Chevy 4400 (parts truck)
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I had 9.00's on my '53 COE 2ton, before I ran across new 8.25's at a good deal. Had no problems, with them. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'll confess I know very little about big truck tires...
But isn't one of the dangers of upsizing the rear tires the possibility that the side walls will rub each other in the rear causing tire failures?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I might ad that 9.00 X 20 10 ply tires's were an option, on the rear of '49-'55 Trucks. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Depends on the width of the rim. A wheel designed for the 700X20 may not work with the 900X20 as the wheel would be narrow and not have enough off set to keep the side walls from rubbing. If you already have 8.25's and they have plenty of space between them 900X20 should be fine. As old sub mentioned sidewalls rubbing can cause tire failure. Underinflation can also cause the sidewalls to rub. | | | | | Joined: Sep 2006 Posts: 38 Junior Member | | Junior Member Joined: Sep 2006 Posts: 38 | The wheels that the 7.00 and 7.25 tires fit is a 6 inch rim, found on most 1-1/2 ton trucks. 9.00x20s will not work on 6 inch wheels because they're too wide and you can't get the outer bead and locking ring on. I do believe you can put an 8.00 on the 6 inch rim but thats the limit.
The 2-ton trucks have the wider 7 inch wheel which accepts 8.00, 8,25,& 8.50s best with 9.00s being the limit. I don't think you'd have to worry about the wider tire sidwalls rubbing, because as stated above, if they're too wide, they won't fit the rims.
kbcsw, you're absolutly right. Underinflated dual sets will rub each other, and left unchecked will cause tire failure.
Rezman
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I'm supposed to have 7.50's on the front. I've got 8.25x20's all around on a 2 ton and they rub on the front frame on a "stop to stop" turn. No problems on the rear at all. | | |
