Going Saturday to check out a 52 one ton and wanted to know if there's anything specific I should what out for. It's a driver so, I will put it through it's paces. My uncle is concerned it will be extra stiff being a long bed one ton. By the pics it's complete and not rotted. In person will tell if that's true.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
That looks like a great truck to start a project with. Glad to see another 1 ton out there. My truck is a 1950 1 ton with the 9' bed, been in our family since new. Specific parts to the 1 ton are the 9' bed sides, longer running boards, longer filler panels between the bed and the running board, and a bit different front bed panel (is available new). The tailgate and most other body parts are shared by the 1/2 and 3/4 ton trucks. Mechanically, the rear brake drums will probably be the hardest thing to get ahold of. Wheel cylinders, master cylinder, brake shoes are all available. These 1 tons will ride pretty stiff, not much comfort was ever built in to them, but it's great driving them, You get a lot of looks when driving them around, I'm sure most young guys today never knew a truck with a stock 9' bed ever existed. I know I will never get rid of mine, good luck on Saturday, don't be scared to take a chance on it just because it's a 1 ton. It is certainly worth restoring, hope you can swing a deal on it if it's something you really want. Thanks, Tom
OH47pickupman It's not a 1-ton,no duals,looks like a 3600 3/4 ton 9 foot bed ,truckernix is right...get on over there and get a grip on that title take cash !! With tire and suspension work you can make that ride like a baby buggy.
It's a downloadable/printable PDF file with all the original GM data and specs you can use to help identify/confirm things on the prospective new truck.
Looking forward to seeing how your visit and prospective deal turns out!
Dan
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
Possum I'm not a ton expert,had I think 2 in my fleet of 30 in about 50 years. Correct me if I'm wrong the ton trucks had a screw on hub cap (the little one about 2 1/2 inches) with a hex made on it maybe 8 flats. 3/4 ton had a drive on cap like a 3100 on the front hubs. I guess we'll see if oh47pickupman lands this one.
Ed Pruss Those are the same wheels my 51 3600 has on a rear axxle installed by a previous owner to haul heavy canned milk.Added spring leaves too. I somehow missed the fact that my ton wheels (same as yours ) are chevy. After several years needed tires,my local tire guy said since that is not a hiway truck we could put on rib-imp worth the money. I cleaned them up with a needle scaler painted with por 15,there still just fine,sleep in out of the weather.
My truck has the cap that taps on, I think it would be the same for oh47pickupman's '52 as well.
According to the Dealer Data Book, on the 3800 model ADs (1-tons), DRWs were an option available on the:
3802/3812 -- Flat faced cowl, and cowl and windshield 3803 -- Cab and Chassis 3808 -- Cab and Chassis with platform body (Flatbed) 3809 -- Cab and Chassis with stakebody
Not available on: 3804 -- Pickup 3805 -- Panel 3807 -- Canopy Express
~ John
1949 Chevrolet 3804 In the Legacy Gallery | In the Gallery Forum 1973 IH 1310 Dump 1963 Kaiser M38A1 2001 International/AmTran RE3000 "Skoolie" 2014 Ford E-350 4x4 (Quigley)
Probably because the "availables" didn't have rear fenders and the "not availables" did.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
Mechanically, the one-tons are a different animal from their 3/4-ton cousins. The frame is the 1-1/2 ton one with pickup-specific axles and wheels, same wheel base. Springs, front and rear, are 2 inch, like the 1-1/2 ton; driveline is open with a carrier bearing in the middle, like the 1-1/2 ton; Front axle is unique to 1-ton as are king-pins and hubs, tie-rod-ends and drag link. Brakes are unique. Look for Bendix brakes, with which some of the earlier one have been retro-fitted. That's worth several hundred dollars extra. All in all, its a much heavier duty pickup and they are hard to wear out. With care it'll likely outlast any of us.
1951 3800 1-ton "Earning its keep from the get-go" In the DITY Gallery 1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
Spot on, Tommy! Here's my unrestored '49 3804 (the Stovebolt.com flagship ) working today. It is a much happier truck with some weight in the back. Huck brakes and bias plys even ...
3800's rock!
~ John
Bill -- That could very well be the case. I have seen two earlier MY 1-tons (see pics below) that were duallie pickups. The '46 is owned by Jim Carter and is a beautiful restoration. It is very factory.
Not sure about the '38. It appears to be a factory job and missing its fender extensions.
I have never seen, smelt nor heard of an AD factory 1-ton Duallie. The data book would tell us that they were not made.
~ John
The Jim Carter truck MAY be factory, but the fit and finish on the '38 has me doubting that it came from the factory. Would the factory have put "tubs" on the inside of the bed?
No particular knowledge on my part, just an opinion.
You raise a valid question, Bill. I think the truck may have been a 1.5-ton, too. An after-market bed then?
~ John
Hopefully Jim can bring his truck to the KC Roundup to tell us more?
Don
1967 GMC 9500 Fire Ladder Truck "The Flag Pole" In the Stovebolt Gallery 1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most!
Pulled the "hub cap" off one of my front wheels today at the show and grabbed a shot of the actual hub cap. the 3804's (or any of the SRW 1-tons) have the press in cap.
~ John
