1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 163 | I finally got my 52 6400 on the road. Wow what an experience. I've driven so rough riding trucks before but this takes the cake, I love it. It's loud, rough, primitive, etc.. I suspect it very similar to a WWII tank.
Regarding the rearend I'm not sure if I'm currently in high or low. I have a lever and moved it back and forth but nothing happened. I suspect there is a technique but I have no idea what it is. Please help. | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Its easy, you drive, turn the two speed knob to the left, lift your foot off the gas, count 1001,1002, and step back down on the gas. It should shift to high. You should feel a little tug when it shifts, and the engine rpms should drop slightly. Alot of times they stop working because of a vacumm leak, someplace in the steel lines running to the back end. If the holes a big one, then the engine will run rough at idle. Another place they go bad is at the bladder located on the diff case. This is a little harder to fix, but not impossible, its just a lot of little bolts that ussally break or have to be cut off. Once inside you find the rubber bladder, that decays over time. I've replaced it with a piece from a rubber boot(the thin kind you slip over a shoe) and had good luck with that. Also sometimes just the shft get gummed up and needs to be cleaned. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I fixed mine with a some rubber pond liner. | | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | I may be confused here; but I have always shifted into LOW by going to the left, and HIGH to the right. The only time I ever double-clutch is if I am split shifting (ie: using the transmission and the 2-speed in combination) Sam 52 Chevrolet 2 ton (Schuyler)
sam
| | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | A vacumn shifted diff, does not need you to push the clutch in while shifting. This info is on the shifting decal, that was part of the truck orginally. You truck may have the lines switched, making you go left to right, but my shift plate clearly shows the lo on the right and the hi on the left. | | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | I remember the decal on the 52 I drove when I was 16 years old: "Driver need not de-clutch". I did check the 2 speed shift, and it is maked Low(on left) and High (on right). Sam the Meat Man 52 Chevrolet 2 ton (Schuyler)
sam
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | How about some pictures of all you folks 2 tons. I love to look at everyone of them. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Ok Virginiafiretruck I AM WORKING ON GETTING MY WEBSHOTS to at the bottom of all my post like yours. Dose not work for me, time for a trip on the IP Short bus. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | | | | Joined: Oct 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 163 | | | |
