| | | Forums66 Topics128,281 Posts1,058,479 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 68 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 68 | Hello everyone, I just put a new 235 in my 1950 Chevy 3100 and when I stabbed the R10 Borg Warner 3 Speed transmission, I cannot get it to engage the motor. I pulled it and made sure the transmission was okay and it seemed to be. I am thinking that the problem may be just the clutch pedal adjustment because I can't think of any other reason it would not engage. Has anyone else had this problem, or know what the issue may be?
Mike
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If the trans is put in high gear for insertion, one can turn the output U-joint by hand to engage the splines in the clutch disc while pushing in.
Ed
| | | | | Joined: Jan 2020 Posts: 68 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 68 | Ed, thanks but it is in all the way. Something must be causing my clutch to engage. I was told that a burr may have caught the throw-out bearing causing it to push on the pressure plate just enough to not allow the clutch plate to engage the flywheel.
Mike
| | | | | Joined: Dec 2020 Posts: 1,989 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,989 | Longer or shorter throwout bearing? Clutch linkage adjustment.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Mar 2007 Posts: 3,501 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,501 | Ed, thanks but it is in all the way. Something must be causing my clutch to engage. I was told that a burr may have caught the throw-out bearing causing it to push on the pressure plate just enough to not allow the clutch plate to engage the flywheel. You may have the clutch plate in backwards.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jan 2022 Posts: 2,522 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,522 | Mike: Your first post says "I cannot get it to engage the motor". A later post says "Something must be causing my clutch to engage."
My feeble mind says that a clutch is ENGAGED when you are driving down the road and NOT ENGAGED when you are stopped waiting for the light to change from red to green.
Which is it?
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Jan 2020 Posts: 68 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 68 | Longer or shorter throwout bearing? Clutch linkage adjustment. It was no wrong throwout bearing, I needed a shorter one.
Mike
| | | | | Joined: Sep 2009 Posts: 6,218 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,218 | Mike, Thanks for following up at letting us know you solved the problem.  When you get the chance, feel free to share some pics of your truck. We would all like to see what your working on.  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
