Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (55shaker, Otto Skorzeny, Hanks custodian, 48JimC), 119 guests, and 5 robots.
Topics128,281
Posts1,058,484
Members48,490
#1490230 03/02/2023 2:20 AM
Hello everyone, I just put a new 235 in my 1950 Chevy 3100 and when I stabbed the R10 Borg Warner 3 Speed transmission, I cannot get it to engage the motor. I pulled it and made sure the transmission was okay and it seemed to be. I am thinking that the problem may be just the clutch pedal adjustment because I can't think of any other reason it would not engage. Has anyone else had this problem, or know what the issue may be?
Mike
Crusing in the Passing Lane
If the trans is put in high gear for insertion, one can turn the output U-joint by hand to engage the splines in the clutch disc while pushing in.
Ed
Ed, thanks but it is in all the way. Something must be causing my clutch to engage. I was told that a burr may have caught the throw-out bearing causing it to push on the pressure plate just enough to not allow the clutch plate to engage the flywheel.
Mike
G Online: Content
Longer or shorter throwout bearing? Clutch linkage adjustment.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Crusty Old Sarge
Crusty Old Sarge
You may have the clutch plate in backwards.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Mike: Your first post says "I cannot get it to engage the motor". A later post says "Something must be causing my clutch to engage."
My feeble mind says that a clutch is ENGAGED when you are driving down the road and NOT ENGAGED when you are stopped waiting for the light to change from red to green.
Which is it?
It was no wrong throwout bearing, I needed a shorter one.
Mike
Mike,
Thanks for following up at letting us know you solved the problem. thumbs_up
When you get the chance, feel free to share some pics of your truck. We would all like to see what your working on. pix
Dan wave
~ Dan
1951 Chevy 3 window 3100
