4 members (MickeyP, KEVINSKI, jay d, Otto Skorzeny), 153 guests, and 2 robots.
Topics128,034
Posts1,055,552
#1490543 03/04/2023 1:26 PM
i have a 61 apache was 6 with 3 on tree. im putting a chevy 302. im using a 61 front engine mount, it looks like a big u. my qustion is its goin behind a saganw 4 speed . what tranny mounts work. can i use the stock mounts ?
1961 apache
chaz71 #1490551 03/04/2023 2:33 PM
Suspending the engine/trans assembly without some support at the bell housing will break the bell housing. You'll need a 1961 V8 bell housing with the hydraulic clutch setup, with the throwout fork and slave cylinder on the passenger's side. Then it will be a bolt-in swap. Saginaw 4 speeds have a cast iron case- - - -no rear mount should be needed, but a universal tubular mount the hotrod shops sell would be an option. DO NOT do the front/rear mount setup without supporting the bell housing.
RLB Offline
I just installed a Gen V 454 in a 66 c10 with manual clutch I used the original 66 bellhousing & new stock rear motor mounts. Worked very well I’m using a m20 4 spd with a 66 11 inch clutch. It all fits like it came from the factory that way. FYI, if your 61 came with a 235 6 cyl, you’ll need to get a v8 bell housing. If you’ve got a later 230 or 250 6, then tha by will fit your 302
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
chaz71 #1490573 03/04/2023 5:12 PM
Assume we are talking about 302 small block V8 and not 302 in-line GMC 6.
BC
1960 C60 pasture art
chaz71 #1490691 03/05/2023 1:49 PM
thank you guys, i did forget to say i have a v8 bell housing behind the 302 v8. and im using the slave from the 6 banger. this is wunderfull news
1961 apache
