0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
#1489117 02/22/2023 6:25 PM
Looking for main bearings for my 54 235. Not making anymore apparently. Looking for 853m20 or 30. Any ideas where to look?
H Online: Content
The later model 235 main bearings with the locator tab at the parting line of the cap and block can be used by modifying the block. The 54-55 year only 235/261 bearings with the locator dowels in the upper bearing can be very difficult to find. I've modified blocks to use either style of bearings in the past, so I know that procedure works.
Justice Go on ebay and watch for a good buy on bearings,bought a set of minus .002's for 40$ "old wheezer" written right on the box. Had been installed,never run worked fine running today !!
Justice,
Was able to do a little web sleuthing this morning and found the following sites that look like they might have what your after (neither are mine BTW):
https://www.northernautoparts.com/part/fm-853m20
https://www.jegs.com/i/Sealed-Power/844/853M30/10002/-1
Neither of these show the item being "out-of-stock". The Jegs listing even indicates they are available for shipping on 03/06/2023.
Hope this is helpful info??? headscratch
Dan wave
~ Dan
1951 Chevy 3 window 3100
H Online: Content
Hey Dan- - - - - -
Maybe you can use your Google-Foo to locate some main bearings I need. A set of .030" undersize mains for a 1948-52 216 or 235 spray-oiler engine. The Federal-Mogul number is a 648M-30 Thanks!
Gdads51 It's interesting that northern auto parts call those .020 over bearings. The railcar load I sold we always called em .020 under ! We sold those all over southern indiana and illinois,then the rings were oversize. In the archives that store had an antiquated align-boring machine for model T type work. This was before the sunnen equipment turned wet and became really accurate.
Justice #1489735 02/26/2023 11:46 PM
Jerry,
I will see what I can do. I think I already tried to chased that rabbit down a whole and lost sight of it once before, but maybe another go at it will locate something??? thumbs_up
Fixite 7,
It amazes me too that the can't seem to get the description right. Another topic I think we have discussed before, right Jerry - lol. not me
Dan wave
~ Dan
Justice #1489744 02/27/2023 12:04 AM
H Online: Content
For some unknown reason, the 1941-47 main bearings have a bore size .002" larger diameter. I have a set of them that look like they will work, but I'd need to put a piece of .001" thick shim stock between the bearing shell and the block, and the cap. I'm not really fond of the idea of doing it that way! If I end up doing it that way, I'll use stainless steel shim stock and red LocTite to assure there's no relative movement.
