1 members (Peggy M),
121
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2021 Posts: 52 'Bolter | | 'Bolter Joined: May 2021 Posts: 52 | Looking for main bearings for my 54 235. Not making anymore apparently. Looking for 853m20 or 30. Any ideas where to look?
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | The later model 235 main bearings with the locator tab at the parting line of the cap and block can be used by modifying the block. The 54-55 year only 235/261 bearings with the locator dowels in the upper bearing can be very difficult to find. I've modified blocks to use either style of bearings in the past, so I know that procedure works. Jerry
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Justice Go on ebay and watch for a good buy on bearings,bought a set of minus .002's for 40$ "old wheezer" written right on the box. Had been installed,never run worked fine running today !! | | | | | Joined: Sep 2009 Posts: 5,837 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,837 | Justice, Was able to do a little web sleuthing this morning and found the following sites that look like they might have what your after (neither are mine BTW): https://www.northernautoparts.com/part/fm-853m20https://www.jegs.com/i/Sealed-Power/844/853M30/10002/-1Neither of these show the item being "out-of-stock". The Jegs listing even indicates they are available for shipping on 03/06/2023. Hope this is helpful info???  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Hey Dan- - - - - -
Maybe you can use your Google-Foo to locate some main bearings I need. A set of .030" undersize mains for a 1948-52 216 or 235 spray-oiler engine. The Federal-Mogul number is a 648M-30 Thanks! Jerry
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Gdads51 It's interesting that northern auto parts call those .020 over bearings. The railcar load I sold we always called em .020 under ! We sold those all over southern indiana and illinois,then the rings were oversize. In the archives that store had an antiquated align-boring machine for model T type work. This was before the sunnen equipment turned wet and became really accurate. | | | | | Joined: Sep 2009 Posts: 5,837 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,837 | Jerry, I will see what I can do. I think I already tried to chased that rabbit down a whole and lost sight of it once before, but maybe another go at it will locate something???  Fixite 7, It amazes me too that the can't seem to get the description right. Another topic I think we have discussed before, right Jerry - lol.  Dan
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | For some unknown reason, the 1941-47 main bearings have a bore size .002" larger diameter. I have a set of them that look like they will work, but I'd need to put a piece of .001" thick shim stock between the bearing shell and the block, and the cap. I'm not really fond of the idea of doing it that way! If I end up doing it that way, I'll use stainless steel shim stock and red LocTite to assure there's no relative movement. Jerry
