1 members (Mike Roache), 58 guests, and 1 robot.
Topics128,078
Posts1,055,938
Members48,430
#1488988 02/21/2023 9:03 PM
After blast and prime I have some rust showing between the layers of metal. There is no way to get in there and no way to stop it from pushing out. I am wondering if I can pour some of the rust converter in there and let it seep in-between the layers of metal?
Then come back and prime paint and caulk it.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
That's worth a try if you can get the stuff to stay in there long enough to work on the rust. Maybe some modeling clay or painters putty dams in the drip rail.
Drill out the spotwelds and remove the drip rails and have them blasted. The holes left by drilling out the spotwelds will greatly aid reassembly location. Or you can do what I did and remove them and don't put them back on. Makes for a very smooth look.
I signed on for a lot of work on this truck, but removing the drip rail is a bit more than I am willing to do. Maybe not putting it back?
I already thought of damming it up to allow it time to seep in. Great minds think alike I guess.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Just a quick note, I stripped mine down to bare metal using sanding and wire wheels. Mine were not rusty so that was not an issue for me but what I did do was to use 3M Self leveling seam sealer to level and blend the seam then after cured sanded the contours. Followed up with Epoxy primer then finish coat. The seam sealer worked very well for filling in the imperfections.
Ron - - Dusty53
1954 Chevy 3604
When we used to put in the fast-n-firm 3m seam sealer, we would pour some lacquer thinner in a little cup and dip our finger in it and rub the seam sealer as smooth as glass.
I think it depends of what year the truck is that determines how the drip rail is removed and or installed.
