3 members (dt235sd, Gdads51, klhansen), 81 guests, and 2 robots.
Topics128,205
Posts1,057,427
Members48,471
Big Bolt Forum Co-moderator
Cleaning up the interior of my 1948 cab. Looks like at one time there was some sort of waffle material attached some how to the interior roof surface. Just curious, but was it some sort of paper product adhered to the roof. I am thinking to putting sound and heat mat on there, then the headliner. Should I just prime the surface and then put the mat on, or is the mat better on bare metal?
1948 Chevy 2-Ton
The mat is only going to stay in place as long as whatever paint you put on. If the paint/primer peels off, so will the mat.
I'd prime the ceiling with a rust converter and then install the hushmat/dynamat/laundromat
1950 Chevrolet 3100 (Ol' Roy)
No, No. Laundromat FIRST, so the paint sticks. wink
Insomniac
Insomniac
Prime with epoxy primer and use spray on adhesive to stick on the insulation. For insulation, I just used the foil backed stuff you can get at the hardware store. Of course, it's hidden by the headliner.
I wouldn't leave any metal bare in our climate. The epoxy primer seals out the condensation. Lesser primers can absorb water.
The 3M spray on adhesive is good. I stuck Dynamat insulation under the hood with it and it is not coming off.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Moderator, Electrical Bay
Most of that was a mix of jute, paper fiber, in some cases horsehair, tar and linseed oil all soaked in some funny-smelling solvent. It was then run through big rollers and let to dry. When I was a boy I got to tour one of the plants making it.
~ Jon
All I know without it gets extremely hot. Mine was off for one summer until I had an upholstery shop fabricate one for me. Mine has a very stiff material for a base then a vinyl cover with a very large outline of the chevy emblem embossed into it. BTW I made a big mistake of touching the inside of the roof.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Moderated by  ndkid275, Phak1
