0 members (),
126
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Cleaning up the interior of my 1948 cab. Looks like at one time there was some sort of waffle material attached some how to the interior roof surface. Just curious, but was it some sort of paper product adhered to the roof. I am thinking to putting sound and heat mat on there, then the headliner. Should I just prime the surface and then put the mat on, or is the mat better on bare metal? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Oct 2021 Posts: 6,965 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,965 | The mat is only going to stay in place as long as whatever paint you put on. If the paint/primer peels off, so will the mat.
I'd prime the ceiling with a rust converter and then install the hushmat/dynamat/laundromat
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2015 Posts: 11,180 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,180 | I'd prime the ceiling with a rust converter and then install the hushmat/dynamat/laundromat No, No. Laundromat FIRST, so the paint sticks.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2000 Posts: 2,207 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,207 | Prime with epoxy primer and use spray on adhesive to stick on the insulation. For insulation, I just used the foil backed stuff you can get at the hardware store. Of course, it's hidden by the headliner.
I wouldn't leave any metal bare in our climate. The epoxy primer seals out the condensation. Lesser primers can absorb water.
The 3M spray on adhesive is good. I stuck Dynamat insulation under the hood with it and it is not coming off.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | Most of that was a mix of jute, paper fiber, in some cases horsehair, tar and linseed oil all soaked in some funny-smelling solvent. It was then run through big rollers and let to dry. When I was a boy I got to tour one of the plants making it.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | All I know without it gets extremely hot. Mine was off for one summer until I had an upholstery shop fabricate one for me. Mine has a very stiff material for a base then a vinyl cover with a very large outline of the chevy emblem embossed into it. BTW I made a big mistake of touching the inside of the roof.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
