3 members (DadsFirstPickup, baldeagle, 1 invisible), 140 guests, and 2 robots.
Topics128,087
Posts1,056,114
Members48,435
#1483587 01/15/2023 3:30 PM
Moderated
Moderated
Help - Trying to ID year on my 235 thanks. Behind starter is (1238) and stamped below distributor is (FI2238), on the head carb side on top of head is (3836848). Thank you for your help. I’m new to this forum.
jack
This should help you figure it out. What you need to look for is the number cast into the block above the right side oil pan flange toward the front of the engine. Just to the rear of the distributor is the engine serial number.
Since this is your first post, Welcome to the site. Suggest that you head over to the Welcome Centre and post an introduction there about your truck and yourself.
For the 1957 model year, Chevy ditched the long serial code. So, looks like you have an engine manufactured at Flint MI on 12/23/56 (for the '57 model year). The '8' you specified on the end of the serial number is likely a 'B'? If it's a 'B' it would have been originally equipped with a Powerglide and should have hydraulic lifters. For confirmation on the year, check the conveyor number above the starter. Yours should be CON# L##6. The 6 at the end the conveyor number means it was made in 1956 (for 1957 model year).
I think this is correct, it's early and I haven't had my coffee yet...others will chime in if I'm off the mark!
Welcome to the forum!!!
Mason
1947 Chevy 3100
-57 Chevy 235
-95 S10 T5 Transmission
-97 Blazer 3.42 Rear End
Sorry, I just noticed you mentioned 1238 behind the starter...could that be L238? If so, it was made Dec 23 1958 which would be for the 1959 model year
Mason
1947 Chevy 3100
-57 Chevy 235
With a build date of Dec 23rd (F1223B), it's unlikely it was machined and assembled on the same day you're saying it was cast.
Could the cast date be Dec 3, 1958 (1238)?
Pictures would help... pix
Welcome to Stovebolt wave
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
