7 members (JW51, J Lucas, papas52, Hotrod Lincoln, Gdads51, DadsFirstPickup, 1 invisible),
104
Mod | | | Forums66 Topics128,162 Posts1,056,953 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | My 1953 GMC has a 235 engine, what is the best sealant for the cork valve cover gasket? | | | | | Joined: Sep 2010 Posts: 2,329 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,329 | White grease is what I put on cork . Was told this years ago seemed to work but I am curious as to what others use also. .. | | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | What year 235? The '53 and earlier ones with 2 acorn nuts often need some tinsmith work done to them before they will ever seal regardless of what you use. The later 235s need to be looked at too to make sure that they are not bent out of shape near the 4 bolt holes. (Consider this a public service announcement for others if you have already made sure yours is straight.)
| | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | | | | | | Joined: Feb 2004 Posts: 29,860 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,860 | The load spreader bars that were originally used on Corvair air cooled engine valve covers make a huge difference in how well a stovebolt cover seals. They also prevent the distortion of the sheet metal in the area of the bolt holes. Clones of the Corvair spreader bars are available from most of the specialty auto parts people like JEGS and Summit. I like to use Permatex Super 300 brush-on sealer. It stays flexible and isn't nearly as messy as RTV and other tube type rubber sealers. Jerry
| | | | | Joined: Jun 2021 Posts: 157 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 157 | My Offenhauser aluminum cover doesn't warp as much than the original. But for good measure, I stick the cork seal to the head with black RTV and just a light coat of HD grease on the upper side.
Works just fine so far.
Frank | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | buckaroo1 I wash the head suface dry then coat the cork gasket with RTV silicon,stick it to the head let it set up overnite. the gasket is sealed so it doesn't let oil soak thru and is like a dam to hold oil in. Put your cover on with light torque,if you need in there it;ll come off and can be put back on easily. Over time you'll have to tighten because oil and heat will make the gasket slowly give up. They once made neoprene gaskets but they got so slippery you couldn't keep it in place. Now I never tried the silicon on that neoprene gasket think that is over. | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | The load spreader bars that were originally used on Corvair air cooled engine valve covers make a huge difference in how well a stovebolt cover seals. They also prevent the distortion of the sheet metal in the area of the bolt holes. Clones of the Corvair spreader bars are available from most of the specialty auto parts people like JEGS and Summit. I like to use Permatex Super 300 brush-on sealer. It stays flexible and isn't nearly as messy as RTV and other tube type rubber sealers. Jerry This is what to use. RTV is horrible, and is the worse stuff to clean off, and won't maintain a good seal unless all the surfaces are surgically clean, not even a finger print is allowed. I rarely use it.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
