Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (NJC, Otto Skorzeny, crenwelge, 3 invisible), 90 guests, and 5 robots.
Topics128,283
Posts1,058,519
Members48,490
#1481537 01/03/2023 3:48 AM
My 1953 GMC has a 235 engine, what is the best sealant for the cork valve cover gasket?
White grease is what I put on cork . Was told this years ago seemed to work but I am curious as to what others use also.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
What year 235? The '53 and earlier ones with 2 acorn nuts often need some tinsmith work done to them before they will ever seal regardless of what you use. The later 235s need to be looked at too to make sure that they are not bent out of shape near the 4 bolt holes.
(Consider this a public service announcement for others if you have already made sure yours is straight.)
It’s a 1955 235engine
The load spreader bars that were originally used on Corvair air cooled engine valve covers make a huge difference in how well a stovebolt cover seals. They also prevent the distortion of the sheet metal in the area of the bolt holes. Clones of the Corvair spreader bars are available from most of the specialty auto parts people like JEGS and Summit. I like to use Permatex Super 300 brush-on sealer. It stays flexible and isn't nearly as messy as RTV and other tube type rubber sealers.
My Offenhauser aluminum cover doesn't warp as much than the original.
But for good measure, I stick the cork seal to the head with black RTV and just a light coat of HD grease on the upper side.
Works just fine so far.
Frank
buckaroo1 I wash the head suface dry then coat the cork gasket with RTV silicon,stick it to the head let it set up overnite. the gasket is sealed so it doesn't let oil soak thru and is like a dam to hold oil in. Put your cover on with light torque,if you need in there it;ll come off and can be put back on easily. Over time you'll have to tighten because oil and heat will make the gasket slowly give up. They once made neoprene gaskets but they got so slippery you couldn't keep it in place. Now I never tried the silicon on that neoprene gasket think that is over.
This is what to use.
RTV is horrible, and is the worse stuff to clean off, and won't maintain a good seal unless all the surfaces are surgically clean, not even a finger print is allowed. I rarely use it.
