2 members (jmoore, Phak1), 85 guests, and 4 robots.
Topics128,184
Posts1,057,270
Members48,467
Has anyone bought this Ring & Pinion for their 55 2nd to 57 Chevy Truck? The price is $392.99. If I was to put this in my truck, what other seals, bearings would a guy need?
And on a difficulty range of 1 to 10 (10 being very hard), where would it fall do you think? For the $330 it looks like you get two pieces only, literally just the ring and pinion.
Lastly, is there a better source than Eckler's? Thanks for any help.
1956 Chevy 3100 Stepside Shortbox
More pix on Photobucket
Other's will be along to answer on install.
There is an "Install" kit which includes seals, bearings bushings, gaskets,ect.
I believe Classicparts , Chevsofthe40's and Fillingstation carries both ring & pinion sets and Install kits.
Good luck
1950 Chevy 3100
Thanks, Classicparts is $50 cheaper, and i see the install kits, complete and lite versions. I assume a guy would just want to buy the complete install kit. Any guesses on what a shop would charge to do this vs having a guy who does it on the side and is reputable?
Thanks Shaffer's1950!!!
I have no idea what it would cost these days. Others will chime in soon. Good luck!
1950 Chevy 3100
My WAG on installation would be in the $1000 plus range at a shop.
Does that include the "Alaska" tax...
Everything seems double..
1950 Chevy 3100
Insomniac
Insomniac
I have a GM 8.5" 10 bot rear end in my truck. I'm thinking of rebuilding it. There are kits available and lots of youtube videos on how to do it.
I think you will need a kit as well as the gear set. e.g. https://shop.advanceautoparts.com/w...=10151&catalogId=10051&langId=-1
Gord 🇨🇦
1954 1/2 ton 235 4 speed
ODSS Lawman
ODSS Lawman
Compared to a closed driveline setup, the open driveline is easier in my opinion having done both. If you have a good attention to detail, and a well written set of directions and the tools it can be done in a one-car garage. Having a press or a friend that does, will help.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
LOL
Sometimes it does seem double. But that was just a Wild-A$$-Guess on my part.
I agree that a reasonably skilled shade-tree mechanic could get the job done by carefully paying attention to instructions.
Maybe I missed something but Classic Parts lists a 3.38:1 ring and pinion for the 55-62 trucks and a 3.55:1 gear set for the 47-54 vehicles. They are not the same.
Maybe Ecklers may have something new for TF trucks, but I don't think so. Be sure you are looking at the correct parts before you buy a bunch of stuff that won't fit.
Fred
