7 members (Hotrod Lincoln, bobfake, GRNHydra, tclederman, Woodcmiami, Otto Skorzeny, 2-Ton), 43 guests, and 2 robots.
Topics128,091
Posts1,056,034
Members48,433
#148091 08/29/2006 1:00 PM
V
V Offline
Is there a location where I can see a picture of the two speed axle linkage on a 51 two ton? I'm trying to connect the two speed dash switch but it seems that I cannot figure out where thing goes. Is there a connection to the rear of speedometer? I know you all are the experts, so I'm asking. I didn't take a picture of this when I took it apart so I'm lost. Here is the back of my speedo. Am I missing a part?
[img]http://www.pinn.net/~vbfd18/1951speedo.jpg[/img]
#148092 08/29/2006 9:51 PM
Yes,that connection to the speedo "shifts" the ratio adapter via a link(small wire)from the two speed switch to keep the speedo accurate.It screws to the back of the speedo head(in line with the cable).You are missing it in your picture.Don't know if a picture is in the shop manual or not.I'll look tonight.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#148093 08/31/2006 12:13 AM
I looked but could not find a picture in the shop manual.Tryed to stand on my head under the dash of my '53 but could not get a part number off that sucker!!Maybe someone else has a picture.
Wanted Good Woman:
#148094 08/31/2006 12:22 AM
V
V Offline
One forum member sent me a picture. I have discovered that when I sent the speedometer in for resoration I had left that part on the back of the spedo. So I've called the company that restored the gage and they are looking for the part. If not found, I'll be searching for a replacement. i thought it might need to be calibrated with the speedometer or I would not have included the adapter when I shipped the gage. Just one more lesson I've learned restoring the Bigbolt!
Anyway, thanks for trying to find the part number.
#148095 08/31/2006 2:16 AM
Virginia firetruck if you can't find your adapter I think I have one from a 58 2 ton, wonder if it is the same?
The White Knight
1941 Chevrolet 1.5-Ton
#148096 08/31/2006 2:07 PM
V
V Offline
Thanks. The restoration company reportedly will take a couple of days to get back with me. I'll look for the answer and get back to you once they let me know if they have found my or an adapter.
#148097 09/04/2006 5:40 PM
This is just a guess on my part, but I wonder if it is a really big deal if you can't find the missing part. IF the speedometer is geared to show the correct speed with the rear end in high range, then the only time you would have an incorrect speed would be when you are in low. You can't go very fast in low, and only use it when you are starting out, or when a hill has pulled your speed down, so an accurate speed at that time is not very important anyway. If I am right, you could just connect the cable directly to the back of the speedometer, and forget it.
Does anyone know if my assumption is correct?
Allen
#148098 09/04/2006 11:48 PM
V
V Offline
BakerAllen: I think you are 100% correct! It looks like it will match up without the adapter. However, I'm just trying to keep the truck like it was in November 1951 except for the fresh air heater which I've added to keep us warm in the winter. I still have not heard back from Chevy Duty or whatever they are called these days... I haven't given up yet!
#148099 09/05/2006 1:14 AM
I'm not certain, but I may know where I can find a used replacement for you. There is a scrap yard near me that has several of these old trucks but I don't know if any of them have two speed axles. These things have been sitting for years,and are full of weeds, rust, bees, probably snakes,and lord knows what else, so I'm not too eager to get into them, but if all else fails, let me know,and I will look into it. Allen
#148100 09/05/2006 1:48 AM
V
V Offline
Thanks. Don't go in there yet as I'm still tracking the one I lost. I'll let you know.
#148101 09/05/2006 1:55 AM
Grigg, Has one listed in the "Parts For Sale" section. I'd get his, & then if you get your original one back, you'll have a spare. It always wise to have spares, of the hard to find stuff. I've probably got at least two, of just about every part, of these 'ol trucks.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#148102 09/05/2006 2:05 AM
V
V Offline
Thanks. I'll take a look as you make a good point!
#148103 09/11/2006 9:10 PM
Hey, check out the swap section, might be what you need...
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
#148104 09/12/2006 1:46 PM
V
V Offline
I sent him an email this morning. Thanks for the "heads up."
#148105 09/14/2006 12:11 AM
V
V Offline
I now have two of the speedometer adapters. Thanks to all for your help.
#148106 09/14/2006 2:27 AM
goodo!
1947 Chevy COE
