| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Is there a location where I can see a picture of the two speed axle linkage on a 51 two ton? I'm trying to connect the two speed dash switch but it seems that I cannot figure out where thing goes. Is there a connection to the rear of speedometer? I know you all are the experts, so I'm asking. I didn't take a picture of this when I took it apart so I'm lost. Here is the back of my speedo. Am I missing a part? [img]http://www.pinn.net/~vbfd18/1951speedo.jpg[/img] | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Yes,that connection to the speedo "shifts" the ratio adapter via a link(small wire)from the two speed switch to keep the speedo accurate.It screws to the back of the speedo head(in line with the cable).You are missing it in your picture.Don't know if a picture is in the shop manual or not.I'll look tonight.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I looked but could not find a picture in the shop manual.Tryed to stand on my head under the dash of my '53 but could not get a part number off that sucker!!Maybe someone else has a picture.
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | One forum member sent me a picture. I have discovered that when I sent the speedometer in for resoration I had left that part on the back of the spedo. So I've called the company that restored the gage and they are looking for the part. If not found, I'll be searching for a replacement. i thought it might need to be calibrated with the speedometer or I would not have included the adapter when I shipped the gage. Just one more lesson I've learned restoring the Bigbolt!
Anyway, thanks for trying to find the part number. | | | | | Joined: Apr 2005 Posts: 32 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 32 | Virginia firetruck if you can't find your adapter I think I have one from a 58 2 ton, wonder if it is the same? | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks. The restoration company reportedly will take a couple of days to get back with me. I'll look for the answer and get back to you once they let me know if they have found my or an adapter. | | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | This is just a guess on my part, but I wonder if it is a really big deal if you can't find the missing part. IF the speedometer is geared to show the correct speed with the rear end in high range, then the only time you would have an incorrect speed would be when you are in low. You can't go very fast in low, and only use it when you are starting out, or when a hill has pulled your speed down, so an accurate speed at that time is not very important anyway. If I am right, you could just connect the cable directly to the back of the speedometer, and forget it.
Does anyone know if my assumption is correct?
Allen | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | BakerAllen: I think you are 100% correct! It looks like it will match up without the adapter. However, I'm just trying to keep the truck like it was in November 1951 except for the fresh air heater which I've added to keep us warm in the winter. I still have not heard back from Chevy Duty or whatever they are called these days... I haven't given up yet! | | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | I'm not certain, but I may know where I can find a used replacement for you. There is a scrap yard near me that has several of these old trucks but I don't know if any of them have two speed axles. These things have been sitting for years,and are full of weeds, rust, bees, probably snakes,and lord knows what else, so I'm not too eager to get into them, but if all else fails, let me know,and I will look into it. Allen | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks. Don't go in there yet as I'm still tracking the one I lost. I'll let you know. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Grigg, Has one listed in the "Parts For Sale" section. I'd get his, & then if you get your original one back, you'll have a spare. It always wise to have spares, of the hard to find stuff. I've probably got at least two, of just about every part, of these 'ol trucks. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks. I'll take a look as you make a good point! | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Hey, check out the swap section, might be what you need... | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I sent him an email this morning. Thanks for the "heads up." | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I now have two of the speedometer adapters. Thanks to all for your help. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | | | |
