1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I'm just wondering, what is the cut off in weight for a standard bellhousing? To rephrase that, would a 1946 2 ton truck bellhousing fit in a 1946 1/2 ton? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the bellhousings are alla same on the 6's, truck GVW don't matter
Bill | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Thanks Bill! I'm trying to get an extra so my engine swap will go smoother. Chevies and GMCs all the same? I thought those big bolts would have used larger clutches or different transmissions. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not sure about if the one from 228, 248 etc GMC fit the Chev - trannies are mostly 4spd back then, but the 3spd fits too - different size clutches fit in the same housing
Bill | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Be sure to give thought to what kind of mounts you want to use;the early style bellhousing with the mounts bolted to the sides won't fit the later style crossmember,and vice versa. Speed | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I believe they do change when you get to the really big GMC stuff, after 3 ton I think? Diesel will be different. If more than 4 speeds could be different? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | he's talkin 46 guys, pretty limited range of engines - a 216 bellhousing is a 216 bellhousing Bill | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | actually 228 bellhousing. And new 302 motor. Truck is a 1940, but should be the same as 1946. Got a hold of a fellow stovebolter who had one in a 1 1/2 or 2 ton 1946 gmc. I wanted to know if they were compatible. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes - as I said, the size of the truck doesn't change the bellhouseing, there's only one - 228/302 same difference
Bill | | | | | Joined: Mar 2005 Posts: 25 Member | | Member Joined: Mar 2005 Posts: 25 | Yes 46 1/2T and 2T. bellhousing are the same, 1948-53 is the years differant than 46 and they are same for 1/2T and 2T. just use a bigger clutch in the 2T. | | |
