1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#147990 08/21/2006 4:29 AM
I'm just wondering, what is the cut off in weight for a standard bellhousing? To rephrase that, would a 1946 2 ton truck bellhousing fit in a 1946 1/2 ton?
#147991 08/21/2006 4:46 AM
the bellhousings are alla same on the 6's, truck GVW don't matter
#147992 08/21/2006 5:11 AM
Thanks Bill! I'm trying to get an extra so my engine swap will go smoother. Chevies and GMCs all the same? I thought those big bolts would have used larger clutches or different transmissions.
#147993 08/21/2006 5:59 AM
not sure about if the one from 228, 248 etc GMC fit the Chev - trannies are mostly 4spd back then, but the 3spd fits too - different size clutches fit in the same housing
#147994 08/21/2006 6:12 AM
Be sure to give thought to what kind of mounts you want to use;the early style bellhousing with the mounts bolted to the sides won't fit the later style crossmember,and vice versa.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#147995 08/21/2006 9:05 AM
I believe they do change when you get to the really big GMC stuff, after 3 ton I think?
Diesel will be different.
If more than 4 speeds could be different?
1952 Chevrolet 3800 pickup
---All pictures---
#147996 08/21/2006 2:14 PM
he's talkin 46 guys, pretty limited range of engines - a 216 bellhousing is a 216 bellhousing grin
#147997 08/21/2006 9:51 PM
actually 228 bellhousing. And new 302 motor. Truck is a 1940, but should be the same as 1946. Got a hold of a fellow stovebolter who had one in a 1 1/2 or 2 ton 1946 gmc. I wanted to know if they were compatible.
#147998 08/21/2006 11:34 PM
yes - as I said, the size of the truck doesn't change the bellhouseing, there's only one - 228/302 same difference
#147999 08/22/2006 1:38 AM
Yes 46 1/2T and 2T. bellhousing are the same, 1948-53 is the years differant than 46 and they are same for 1/2T and 2T. just use a bigger clutch in the 2T.
