9 members (55shaker, 1955 1 Series, BC59, 3800GUY, RaNfLaS, tclederman, Otto Skorzeny, wilbur53, FAST55), 156 guests, and 0 robots.
Topics128,104
Posts1,056,201
Members48,436
Is there a option for a smaller stock looking wheel? I am adding PS and will not need the large one.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Sir Searchalot
Sir Searchalot
Lots of options. Most GM splines are the same.
I added PS in my 49-3100 but kept the stock (big) wheel to keep the original look.
Sir Searchalot
Sir Searchalot
PS or not, larger the wheel , easier the effort.
Most after-market wheels come in different sizes. I bought a Lecarre and the horn did not last more than 3 months and kept blowing when I turned the corner. I thnk it was over $300.00.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I have thought about the stock look. Mine has a few cracks on it. I figure I can fill and paint it. It will wear in like the original I would guess.
If I get much fatter I might not be able to fit behind it? I am 6'0 and 250 lbs.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Curmudgeon
Curmudgeon
Wow Buoymaker. That is an amazing article.
I don't see how he didn't simply shatter all the plastic when he reduced the diameter of the wheel? Cutting the center arms back is easy, but reducing the diameter would result in the covering flying everywhere?
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Thought about this all weekend. I think I am going to try it as I get closer with the re-assembly.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Nicely done. thumbs_up
2017 Buick Encore
See more pix
That was pretty cool. Reducing the diameter worked well because he had a jig made up with the blocks spaced enough so things didn't kink. The plastic coating is just that (plastic) and so shouldn't crack when it was bent to the smaller diameter. A wheel that's gone brittle might have issues, though.
I'm fat to.I have a 49-3100 with original steering wheel. I wanted the big wheel for original look, but my belly was to big. Took the back of the seat to a shop and they removed all the thick padding and springs and installed one layer of foam. My belly does not rub on the wheel and my back is just fine with the one layer of foam.
Well. When I get closure to installing the column I am going to try it. My plastic has cracks which will need to be repaired anyway, so may as well do it all at once and see what happens.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
