4 members (klhansen, FAST55, 69Cuda, dt235sd), 120 guests, and 5 robots.
Topics128,050
Posts1,055,667
#147941 08/16/2006 3:03 PM
I am trying to finish up a nine year restoration project. I have a 41 1 1/2 ton super duty! ready for battle if it were not for the brakes. Here is the situation, new rear wheel cyls., & master, hoses and lines, rebuilt front wheel cyls,.and Hydrovac. NO visable leaks. I bled the lines starting with Hydro, front, then rear. I get af irm peddle, start engine, step on brake firm, step on peddle again brake goes to floor. What is up? Help! Joe
The White Knight
1941 Chevrolet 1.5-Ton
#147942 08/16/2006 5:12 PM
If you are loosing fluid, my guess would be that the hydro is leaking internally. My 48 did that, I by-passed it to confirm my diagnoses.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
#147943 08/16/2006 7:30 PM
I am not losing fluid. It acts as if it has air in the lines. I just can't seem to get it out.
The White Knight
#147944 08/16/2006 8:07 PM
LOCKLAND 41
I would pressue bleed the brakes from the wheel cylinders up this should push all the air out of the system.
#147945 08/16/2006 10:30 PM
Make sure all of the shoes are properly adjusted, each shoe needs to be independently adjusted on the big trucks.
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#147946 08/23/2006 12:36 AM
Scott,
Thank you for the tip. That was it. I put the wheels on some time back and left them loose on purpose so they wouldn't lock up, and then I forgot. That is what happens when you stretch a project out over nine years. Thanks again guys it is almost ready for its first cruise in, then it's off to the gravel pit where it will no doubt win best of show!
Joe Newton
The White Knight
