0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#1479005 12/15/2022 4:49 PM
Dexstar Conventional Steel Wheel - 16" x 6" Rim - 6 on 5-1/2 - Black Powder Coat / Item # AM20758
Wondering if anyone has used the rim listed above and if they'll fit on a 1st series 3100 without any tie-rod mods? I'm going to mount 215 85R 16 tires on my '53. Discount tire won't mount these tires on my original rims. I've read members posts stating they've mounted this size tire on original 4 1/2" rims with no problems so my plan is to mount the tires myself then have a local tire shop spin balance them. I'm already running tubeless bias ply tires, so my rims are good. Just checking my options and curious to see it the Dexstar wheel will work.
Thanks!!
George
AD3100 #1479033 12/15/2022 6:12 PM
I purchased 16"x6" rims (3.5" back space) from Wheelsmith and they fit fine on the stock brake drums with stock steering and suspension.
I mounted 225/70 R16 wheels but had planned to mount the 215/85 R16 tires. The only reason I didn't was due to the much higher cost per tire.
I have 215/85 R16 tires on my Packard that has 4.5" rims. They fit and handle great.
1950 Chevrolet 3100 (Ol' Roy)
AD3100 #1479043 12/15/2022 6:55 PM
Thank You!!!! Do you recall what the Wheelsmith price per wheel was. I'm looking to get a set of 5.
AD3100 #1479053 12/15/2022 7:16 PM
They were $217 each for bare steel Smoothie. I opted to have them powder coated.
$60 each for powder coat for a total of $277 per wheel.
Some sort of host server issue is preventing the pictures from attaching properly.
AD3100 #1479058 12/15/2022 7:46 PM
Thank you again. Vintage smoothies are what I'm looking at. These might be my Christmas present to myself.
AD3100 #1479070 12/15/2022 8:13 PM
You're welcone, AD.
I'm extremely pleased with these wheels. They are very high quality. They'll powder coat them in whatever color you choose but they can't match original paint colors. If you want an original body color wheel, you'll need to order the bare steel version and paint them yourself.
I opted for gloss black and ordered a new set of hubcaps from them. If you have original caps, they will make the rims for you with the proper clips to hold your original caps.
My truck had crummy 15" trailer wheels on it and looked and handled like crap. I considered buying used Chevy wheels but finally decided the best thing to do was buy all new rims. If I did it again, I would probably buy 5" rims instead of 6' rims to be closer to the original look.
AD3100 #1479071 12/15/2022 8:22 PM
Since they're custom made 5" would be the way to go. I'm glad I posted this question and the right member saw it!!
Very much appreciated!!!
George
AD3100 #1479080 12/15/2022 9:06 PM
You might look here. I have a set on my 54 but nothing special except the are drilled for both ford and chevy bolt patterns. I have a pacer front end and a Nova rear end with 2.73 gears.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
AD3100 #1479240 12/16/2022 7:29 PM
Thanks. I need 6 on 5.5 pattern.
AD3100 #1479255 12/16/2022 8:47 PM
...tell me about the rabbits, George...
Here are the pictures that wouldn't post the first time. 6"x16" Smoothie, 6x5.5 bolt pattern, 225/70R16 Firestone tires.
AD3100 #1479266 12/16/2022 9:20 PM
Those are beauties!!!!
I'm going with Wheelsmith smoothies for sure with Michelin 215 85R 16 XPS Rib tires.
You've been a great help!!!
AD3100 #1479268 12/16/2022 9:24 PM
Post a picture of the tires you're getting.
When you get your new rims and tires installed, post before and after pics of your truck.
As a reminder, original caps will not fit on the smoothies unless you have Wheelsmith install the clips for you. They sell original style caps that fit on the smoothies.
AD3100 #1479270 12/16/2022 9:46 PM
I think I'll go with their baby moons and smooth trim ring.
I'll post pictures but it will be after the new year.
AD3100 #1479271 12/16/2022 10:01 PM
Of course. When I ordered mine, it was 4-6 weeks lead time.
