8 members (Gdads51, 55shaker, 32Fordpuchoptop, dwreills, chevy51truck, Phak1, klhansen, 1 invisible), 122 guests, and 3 robots.
Topics128,036
Posts1,055,458
Members48,422
Hi All,
I may have asked this some time ago but cant find it. My window frame will be coming in week or so and I want to seal this NOT using the permanent sealer that my previous mechanic used on the old (bent) frame. Just in case a stone hits the windshield. I really need something that allows me to more easily get the windshield out. This truck will rarely if ever see rain. Cant I use some sort of int/ext clear sealant from home depot for the small amount of weather this truck will see?? headscratch ohwell
sorry, I have a 1938 as in my sig and handle. Forgot to mention just in case.
'38 1.5ton; "The stuff is as tough as woodpecker lips"
I was thinking it would be more of a tube to like cauk gun type sealant.
I suppose you can get it that way too. Just do a search, actually I think I saw it that way when I was looking for the stuff I linked to. Personally I'd rather be able to use a small applicator and pull back the seal with a seal tool to put in where I want it. I don't think you want sealer any place while your using a rope to install the window and rubber seal. Maybe some sealer in the channel for the glass before install because it would be next to impossible to get sealer there after the install. But around the pinch weld that could be done after the install, I think.
I believe what you want is the 3M 08509 Bedding Compound , its remains pliable and its what's recommended by other bolters and also Steele Rubber Products. It comes in tubes just like regular caulking.
Ron - - Dusty53
1954 Chevy 3604
