| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | Hi All, I may have asked this some time ago but cant find it. My window frame will be coming in week or so and I want to seal this NOT using the permanent sealer that my previous mechanic used on the old (bent) frame. Just in case a stone hits the windshield. I really need something that allows me to more easily get the windshield out. This truck will rarely if ever see rain. Cant I use some sort of int/ext clear sealant from home depot for the small amount of weather this truck will see??  sorry, I have a 1938 as in my sig and handle. Forgot to mention just in case.
'38 1.5ton; "The stuff is as tough as woodpecker lips"
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 |
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | I was thinking it would be more of a tube to like cauk gun type sealant.
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | I suppose you can get it that way too. Just do a search, actually I think I saw it that way when I was looking for the stuff I linked to. Personally I'd rather be able to use a small applicator and pull back the seal with a seal tool to put in where I want it. I don't think you want sealer any place while your using a rope to install the window and rubber seal. Maybe some sealer in the channel for the glass before install because it would be next to impossible to get sealer there after the install. But around the pinch weld that could be done after the install, I think.
| | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | I believe what you want is the 3M 08509 Bedding Compound , its remains pliable and its what's recommended by other bolters and also Steele Rubber Products. It comes in tubes just like regular caulking.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | |
