Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Hotrod Lincoln), 195 guests, and 2 robots.
Topics128,290
Posts1,058,566
Members48,492
Hello all! Just joined here not all that long ago -- although I have been a lurker for quite a while.
This is going to get a bit long winded so bear with me please.
So what I have been looking for for quite some time is anyone who can give me details of how a 901 1-ton truck bed is built on a 1928. I have done quite extensive web research looking at many many pictures. Found lots of pictures of home built beds, that look real close, but the 901 bed has clad steel sides, and hides the wood under the bed. From the picture I have found, it also looks like the bed floor framing is clad separate from the sides.
I don't think it is built like a stake box where it has the two long beams that bolt to the main frame. It doesn't appear to ride high enough on the truck for that. But if it doesn't have main beams under it, at 8 feet long, IDK how the rear part of the bed that cantleavers over the frame would be supported. I believe the floor boards themselves to be 1-1/4" thick, so this may allow it to hang over without beams once the vertical sides are fastened to it.
As to the sides: they have steel straps with the bend to them that allow for a flare board at the top. They lay to the inside of the box, not over the outside steel-cladded wood. The bed sides are made of more than one piece of board and these straps join the board sides together (I believe the sides to be two boards high).
I also think these steel straps may be made of hammered round stock so they end up with a threaded stud on the bottom so they bolt through the floor holding the sides on. This is much like how a horse drawn wagon is built from what I can tell. I know that there are like just flat 1/8" x 1-1/8" or 1-1/4" steel slats over the floor board seems that are not routered in, so they stand above the wood. IDK how they are fastened, but there is one member here (Bearsfan with the blue Huckster pictures on here) that has good pictures of how the strips are fastened on his bed. Whether it is correct or not, I am unsure.
I am a member on the VCCA site as well and have a thread over there, and got a fair amount of info out of a member there, but need more.
I also reached out to several other members by private message, but didn't find any that had that type of box on a 1-ton truck. Hopefully, someone here can help me re-create this bed for my truck.
Attached is the 901 box, and here is a link to the VCCA discussion. It actually talks of my truck being a 27LM, but clues along the way have led me to believe it is more likely an early 28LO. Dean over there posted a lot of good photos of his huckster box, but that is a 1/2-ton chassis, so frames are different I think than a 1-ton would although there are construction similarities.
David
Attached is a box that is built on a 1-ton chassis that shows the detail better of the separate cladding between bottom frame and sides.
Hi, not sure if these photos will help or not. Good luck,
Mike
They are from a 1933 Chev 1.5 ton.
Moderated
Moderated
I'm a little late to the party, but here is what i did with my 1928 LO.
1954 Chevrolet 3600
1930 Chevrolet Coupe
1928 Chevrolet Cabriolet
1928 Chevrolet LO 1 ton
1927 Chevrolet pickup
1925 Chevrolet Touring
1918 Chevrolet 490 Touring
Authorized Pest
Authorized Pest
TD, Can you offer any details that David is looking for? Maybe even some close-ups of the bed. Hope we hear back from Dave. Thanks for the pix of your '28 tho. grin
Also, the "Blue truck" of Bearsfan315 is in the Gallery Forum. He's got some great photos of the bed there. And his story of the 1930 Chevrolet AD Universal - Canopy Express Truck is in the Legacy Gallery.
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
Moderated by  John Milliman
