2 members (Hotrod Lincoln, KCMongo), 59 guests, and 1 robot.
Topics128,050
Posts1,055,639
#1475481 11/16/2022 4:07 PM
Not sure if this is where it belongs, and if need be, it can be moved.
I'm trying to replace the heater core on my 64' with the original Thrift Air. I know I've replaced it before, as well as the blower motor and serviced the squirrel cage, but for some strange reason,(age related I'm sure) can not get the top cover off the heater box. My question is... is there some screws along the firewall inside the cab(behind the glove box) that I'm missing?
Thanks for the help.
Tramp
dj durant
More pix on Flickr
Tramp #1475530 11/16/2022 8:20 PM
Alright boys and girls.
After plenty of rectal irritation and numerous skinned knuckles, I found the 2 studs on the firewall inside the cab to get the heater box divorced from the truck. Had to take the glove box apart for access. Wait a minute!!! Just when you think you've got it whipped, you'll find 4 tiny sheet metal screws on the back side of the box to finally cause everything to come apart. Now I can take some time and clean everything up and spray some paint while I wait for the new core to get here from my NAPS (neighborhood auto parts store).
The boss lady says with some professional therapy and the proper medication, my attitude should change enough for me to qualify as a grumpy old man instead of being completely intolerable trying to figure out how something is supposed to work. The dogs don't even want to be around me.
Hope everyone is doing well and staying warm. Take your toys out and play with them and it'll do wonders for your mood.
Tramp
dj durant
More pix on Flickr
Tramp #1475541 11/16/2022 10:28 PM
Sir Searchalot
Sir Searchalot
Venting is good. Consider us as your focus group any time. Glad you got the cover off. Can't help with the wife and dogs. Don't have a sub forum for that yet. Keep plug'in away. If you stop moving you will rust.
Tramp #1475980 11/20/2022 11:39 AM
Tramp Sounds about right,put Vick's Vapo-rub on your skinned places when I done it for real next day skin would be soft enough you could work without bandages, then stay out of the dirt best you could. Done it that way many times. My round heater core has found a piece of rust to fit the leak,so is not leaking for now ! Always good to vent,wife and dogs will come back and cruise once it's fixed !! Find,fix,drive it.
Tramp #1485008 01/25/2023 12:21 PM
Tramp Well we are getting snowed-in right now,took your advice and got out toys yesterday pulled the warm truck out and sat facing fairly bright sun for a while. Brine all over things out on the hiway so will stay in out of that.I assume your heater core is in ,wife and dogs came back,can now cruise ! Hands grew back from heater core change.
