| | | Forums66 Topics128,043 Posts1,055,609 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Not sure if this is where it belongs, and if need be, it can be moved. I'm trying to replace the heater core on my 64' with the original Thrift Air. I know I've replaced it before, as well as the blower motor and serviced the squirrel cage, but for some strange reason,(age related I'm sure) can not get the top cover off the heater box. My question is... is there some screws along the firewall inside the cab(behind the glove box) that I'm missing? Thanks for the help. Tramp | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Alright boys and girls. After plenty of rectal irritation and numerous skinned knuckles, I found the 2 studs on the firewall inside the cab to get the heater box divorced from the truck. Had to take the glove box apart for access. Wait a minute!!! Just when you think you've got it whipped, you'll find 4 tiny sheet metal screws on the back side of the box to finally cause everything to come apart. Now I can take some time and clean everything up and spray some paint while I wait for the new core to get here from my NAPS (neighborhood auto parts store). The boss lady says with some professional therapy and the proper medication, my attitude should change enough for me to qualify as a grumpy old man instead of being completely intolerable trying to figure out how something is supposed to work. The dogs don't even want to be around me. Hope everyone is doing well and staying warm. Take your toys out and play with them and it'll do wonders for your mood. Tramp | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Venting is good. Consider us as your focus group any time. Glad you got the cover off. Can't help with the wife and dogs. Don't have a sub forum for that yet. Keep plug'in away. If you stop moving you will rust.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Tramp Sounds about right,put Vick's Vapo-rub on your skinned places when I done it for real next day skin would be soft enough you could work without bandages, then stay out of the dirt best you could. Done it that way many times. My round heater core has found a piece of rust to fit the leak,so is not leaking for now ! Always good to vent,wife and dogs will come back and cruise once it's fixed !! Find,fix,drive it. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Tramp Well we are getting snowed-in right now,took your advice and got out toys yesterday pulled the warm truck out and sat facing fairly bright sun for a while. Brine all over things out on the hiway so will stay in out of that.I assume your heater core is in ,wife and dogs came back,can now cruise ! Hands grew back from heater core change. | | |
