0 members (), 132 guests, and 1 robot.
Topics128,285
Posts1,058,276
Members48,483
#1474309 11/07/2022 5:35 PM
What headers fit the 1947-1954 with a v8?
Headers are eye candy at the speeds street driven engines run most of the time. All they're really good for is increasing under hood temperatures, leaking, and burning up spark plug wires. Use a 1955-57 265 V8 exhaust manifold on the driver's side for steering shaft clearance, or the rear-exit manifolds for a mid-1980's 305 engine to make both sides look similar.
I am going through the same conversation with friends of mine. I don't want to use them, but to get the most out of my engine I probably should. Realistically using my engine to its ability will happen a few times a year.
So I have found ram horns with 2.5" exit, all weird mounting tabs are removed, etc, for less than $200. They look the part, I will coat them with the stove polish so they don't rust, and then do a 2.5 inch exhaust. I will loose 50-70 hp on the high end, but the tires will already be spinning at that point so who cares.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Ferris Bueller #1474681 11/10/2022 5:54 AM
The person who told you that should be talking to my garden- - - - -I'd save a fortune on fertilizer!
