0 members (),
144
Mod | | | Forums66 Topics128,285 Posts1,058,275 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2022 Posts: 24 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 24 | What headers fit the 1947-1954 with a v8? | | | | | Joined: Feb 2004 Posts: 29,933 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,933 | Headers are eye candy at the speeds street driven engines run most of the time. All they're really good for is increasing under hood temperatures, leaking, and burning up spark plug wires. Use a 1955-57 265 V8 exhaust manifold on the driver's side for steering shaft clearance, or the rear-exit manifolds for a mid-1980's 305 engine to make both sides look similar. Jerry
| | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | I am going through the same conversation with friends of mine. I don't want to use them, but to get the most out of my engine I probably should. Realistically using my engine to its ability will happen a few times a year.
So I have found ram horns with 2.5" exit, all weird mounting tabs are removed, etc, for less than $200. They look the part, I will coat them with the stove polish so they don't rust, and then do a 2.5 inch exhaust. I will loose 50-70 hp on the high end, but the tires will already be spinning at that point so who cares. | | | | | Joined: Feb 2004 Posts: 29,933 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,933 | I will loose 50-70 hp on the high end The person who told you that should be talking to my garden- - - - -I'd save a fortune on fertilizer! Jerry
