3 members (Chip O, Charles in CA, 1 invisible),
159
Mod | | | Forums66 Topics128,087 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 39 Member | | Member Joined: Jun 2006 Posts: 39 | Did chevy ever make a 2 speed rear axle like the internationals for their larger trucks? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Well I don't think Chevy actually made it, but a 2-speed axle was an option in the bigger trucks.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I would assume you know that a two speed gives you a slow and slower rear ratio. Some people think you can go faster if you have a two speed rear, not so. If you swap a two speed where you had a single you are most likely swapping to a lower, slower on the road, ratio. | | | | | Joined: Dec 2005 Posts: 66 New Guy | | New Guy Joined: Dec 2005 Posts: 66 | Got two speed rears on both my '48 2t. chevy dumps. Even have decals on the dash with instructions. Looks factory to me. | | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | Chevrolet first offered a 2 spd. axle in 1939. | | | | | Joined: Jun 2006 Posts: 39 Member | | Member Joined: Jun 2006 Posts: 39 | Grigg:
So a two speed axle won't add a higher ratio to 6:16 differential gears? You're right, I thought that would add taller gears for faster highway speeds. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dale in Iowa,
I have never seen a two speed rear end offer any other choices than...the ratio allowed by the ring and pinion, and one lower. If you can install a auxiliary transmission (brownie), you can get a overdrive ratio.
Stuart | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Dale - the 2 speed would be about 6.40 and 8.72 Bill | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dale in Iowa, I might using the term "lower" incorrectly. When I think of a low gear, I guess it really is a "high" ratio. So the two speed will give you the ratio of the installed ring and pinion, and a optional higher ratio, which will result in a slower speed, but more torque! Clear as mud. Stuart | | | | | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | Here is some additional technical specifications on the single and two-speed rear axles for the medium duty trucks... | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | When I got my '57 Fire Truck it had a 7.17:1 single speed rear and had a top speed of about 53 mph. It has an 18,000 pound Eaton rear, so I found a 2-speed pumpkin (that fit my housing) that had a higher high ratio and a lower low 6.14/8.36:1. I added 10 mph on the top side and have a deeper low for pulling (Granny and 'Low Rear' will pull a house down). I drive it like a 6-speed, set the rear to 'low rear' and work up to 5th low then shift the rear to 'high'...I'm very happy with the results. When we convoy to truck shows I never hear I'm holding the group back...I'm usually out in front leading the way! Mike B  | | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Hey Big Dogs, I wonder if you can help me out. I have a '57 3600 one ton dump and the little dogs only have half and three quarter trucks so I come to you my Big Dog brothers with a question about rear ends. My GM 10 bolt 11 inch is geared so stinkin' low (probably 4.57) it's cruel. At 50 mph that 350 engine is really whirlin'. This thing has power aplenty; I just hauled 4000 lbs, taking off in second gear no problem. I'm told they don't make aftermkt gears for this thing. I can hang an aftermkt overdrive where the carrier bearing sits for only 3k!!! Any thoughts about a two speed axle???? or other solutions to my screaming dilema??????? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Skip, Try posting a new topic with your questions, I am sure you will get more responses than tacking on the end of this one. Grigg | | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Dude (I'm from California), Thanks! | | |
