5 members (Peggy M, Hush, MNSmith, Phak1, tclederman), 148 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#147367 07/10/2006 4:13 AM
Did chevy ever make a 2 speed rear axle like the internationals for their larger trucks?
#147368 07/10/2006 4:28 AM
Well I don't think Chevy actually made it, but a 2-speed axle was an option in the bigger trucks.
#147369 07/10/2006 10:01 AM
I would assume you know that a two speed gives you a slow and slower rear ratio.
Some people think you can go faster if you have a two speed rear, not so. If you swap a two speed where you had a single you are most likely swapping to a lower, slower on the road, ratio.
1952 Chevrolet 3800 pickup
---All pictures---
#147370 07/10/2006 10:49 AM
Got two speed rears on both my '48 2t. chevy dumps. Even have decals on the dash with instructions. Looks factory to me.
#147371 07/10/2006 1:09 PM
Chevrolet first offered a 2 spd. axle in 1939.
#147372 07/10/2006 1:43 PM
Grigg:
So a two speed axle won't add a higher ratio to 6:16 differential gears? You're right, I thought that would add taller gears for faster highway speeds.
#147373 07/10/2006 2:39 PM
Dale in Iowa,
I have never seen a two speed rear end offer any other choices than...the ratio allowed by the ring and pinion, and one lower. If you can install a auxiliary transmission (brownie), you can get a overdrive ratio.
Stuart
#147374 07/10/2006 3:11 PM
Dale - the 2 speed would be about 6.40 and 8.72 eek
#147375 07/10/2006 3:46 PM
Dale in Iowa,
I might using the term "lower" incorrectly. When I think of a low gear, I guess it really is a "high" ratio. So the two speed will give you the ratio of the installed ring and pinion, and a optional higher ratio, which will result in a slower speed, but more torque! Clear as mud. smile
Stuart
#147376 07/10/2006 7:21 PM
Here is some additional technical specifications on the single and two-speed rear axles for the medium duty trucks...
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
[b]Burgie's 1964 Chevy C60 Restoration Site[/b]
#147377 07/11/2006 4:05 AM
When I got my '57 Fire Truck it had a 7.17:1 single speed rear and had a top speed of about 53 mph. It has an 18,000 pound Eaton rear, so I found a 2-speed pumpkin (that fit my housing) that had a higher high ratio and a lower low 6.14/8.36:1. I added 10 mph on the top side and have a deeper low for pulling (Granny and 'Low Rear' will pull a house down). I drive it like a 6-speed, set the rear to 'low rear' and work up to 5th low then shift the rear to 'high'...I'm very happy with the results. When we convoy to truck shows I never hear I'm holding the group back...I'm usually out in front leading the way!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
#147378 07/23/2006 6:21 AM
Hey Big Dogs, I wonder if you can help me out. I have a '57 3600 one ton dump and the little dogs only have half and three quarter trucks so I come to you my Big Dog brothers with a question about rear ends. My GM 10 bolt 11 inch is geared so stinkin' low (probably 4.57) it's cruel. At 50 mph that 350 engine is really whirlin'. This thing has power aplenty; I just hauled 4000 lbs, taking off in second gear no problem. I'm told they don't make aftermkt gears for this thing. I can hang an aftermkt overdrive where the carrier bearing sits for only 3k!!! Any thoughts about a two speed axle???? or other solutions to my screaming dilema???????
#147379 07/23/2006 3:15 PM
Skip,
Try posting a new topic with your questions, I am sure you will get more responses than tacking on the end of this one.
Grigg
---All pictures---
#147380 07/23/2006 7:30 PM
Dude (I'm from California), Thanks!
