7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen), 117 guests, and 1 robot.
Topics128,081
Posts1,056,068
Members48,433
#1473003 10/29/2022 5:43 AM
Did they ever use an on the column collar type switch arrangement like found on 1957 up? Or do they all have the goofy aftermarket switch held on by a hose clamp?
I thought I knew these Taskforce trucks real well, things are a bit different on the 55, its like they were learning on them.
Crusing in the Passing Lane
My 55.2 GMC has the factory turn signal switch, 6 V system.
Ed
My 55.2 Chevy 3100 also has the factory turn signal switch, 12-volt system.
Brian
1955.2 3100 Truck
Curmudgeon
Curmudgeon
1954 was the first year for Chevy trucks to get factory turn signals.
Many of the parts were the same (except casting housing date stamp) as those used on cars in 1953.
I think, by your questions, you are finding out that a restoration involves a lot of research.
Stovebolt members try to help each other but remember we are human and make mistakes.
Investing in some documentation helped me and continues to help.
Chevrolet Master Parts manual
Owner's manual
Shop manual
Factory Assembly Manual
Dealer's Data Book
Chevrolet Accessories / Installation Manual
Those trucks were sold as basic transportation back then and many for farm and industrial use. Many were purchased without the available options like turn signals, radios, heaters, electric wipers, and rear bumpers. Most didn't have a fuse block unless options were ordered. Several aftermarket suppliers offer the factory style turn signal switch.
Fred
Owner's manual
Shop manual
Dealer's Data Book
If it was a 57 on up would not be so many questions.
I'm finding out things are a bit different on these older TF trucks, a few things a bit better and some not so, its like the factory workers where learning on them.
My 56 came with the factory TS switch and system. I have seen numerous 55's with and many without. I have also seen
several 57-59's without.
However, this is by no means a scientific sampling or representation. Some buyers felt they needed them, others did not.
I have seen trucks that came with the factory switch that someone wired around with an aftermarket switch as well.
Not sure when the states mandated turn signals, probably about 1960.
Fred
I am almost sure that my 54 3100 had them when I bought it in 1983. It has a modern column now.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Turn signals weren't federally mandated for all vehicles in the USA until 1968.
1950 Chevrolet 3100 (Ol' Roy)
