4 members (MNSmith, Dennys28, dwreills, Ponchogl), 105 guests, and 2 robots.
Topics128,042
Posts1,055,518
Members48,424
#1473095 10/29/2022 11:19 PM
Good Saturday evening bolters!
The left bedside on my 51 is rattling while driving, and if you look at the attached photo, you can see the gap between the angle bed floor strip and the bed side. Anyone have a suggestion on how to take up the gap and or stop the rattle?
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
kthomas #1473098 10/29/2022 11:29 PM
It looks to me like the angle strip has pulled loose from the bed side. It would have been spot welded on from the factory.
Unfortunately, without repainting, the only solution I see is to drill holes and put some bolts in to secure it to the bedside. Is this an original bedside that you've restored and painted, or an aftermarket one that came with the angle strip attached? If the latter, I would contact the supplier about it.
klhansen #1473099 10/29/2022 11:34 PM
Originally Posted by klhansen
Good point on the weld, I had forgotten that was how the angle strip is secured. I bought the truck already restored and I am not sure it the angle strips are original or aftermarket.
Thanks for the feedback.
kthomas #1473121 10/30/2022 2:01 AM
Just a thought most new ones are glued together, maybe if it is clean between the parts some of that panel bond stuff may work. I know absolutely nothing about the stuff but seen a documentary on how new trucks are glued together on a lot of the panels .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
kthomas #1473122 10/30/2022 2:09 AM
Panel bond may work, but figuring out a way to push the parts together might be difficult. Might be worth a try.
Shall we call this the Kevin - Kevin - Kevin thread? grin
kthomas #1473158 10/30/2022 1:49 PM
You just fill the gap with black silicone and let it dry a few days, that will take the rattle out. Panel bond would also work, but since it's not a working truck, you don't really need the strength of panel adhesive. Can you get a bar clamp under the bed and above the frame rails?
kthomas #1473163 10/30/2022 3:22 PM
I'd suggest you drill a hole through the angle and bedside and pull it together using a pan head bolt with the pan head on the "inside". If the nut is visible on the outside ( not under the fender ) use the shortest bolt possible then use touch up paint to "hide" the nut or just paint the nut/washer flat black to reduce visibility. Ok, it's no longer the Kevin-Kevin- Kevin thread.
Ron - - Dusty53
1954 Chevy 3604
Dusty53 #1473239 10/31/2022 12:13 AM
LOL, heck yeah!
kthomas #1473240 10/31/2022 12:14 AM
Thanks for the suggestions guys, I appreciate them! I may end up drilling a couple holes on each side and using panhead bolts.
Dusty53 #1473241 10/31/2022 12:18 AM
Thanks Dusty, I think that is what I am going to do.
