| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 75 | Is the cab on my 65 C 50 wrecker the same as the C 10 1960-66 I need a lot of sheet metal for it. (door skins-floor to side wall panels- door-windshild rubber- etc-etc ) am I wasting my time looking at C10 repo stuff. Thanks Lou. H. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | pretty much the same, there are some difference in the floor & firewall but not where they normally rot. brian | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Only the 64-66's are alike. 60-63 have different w/shields and doors, Scott | | | | | Joined: Mar 2004 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 75 | Thanks guys I didnt know they made cab changes in the middle of a series. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Lou Basically What Scott said 60 thru66 had the same body style Fleet or step sheetmetalwise 1/2 ton to 1ton CAB Wise With the ton and a halfs and bigger the fenders were bigger Major difference CAB sheetmetalwise is between 63 and64 60 thru 63 has a wraparound windshield called"panoramic" by GM and consequently the doors are totally different. 64 thru 66 have a so called "flat" windshield and GOD knows I Blessed Him Countless times After NOT sliding out and Smacking my Knee on that DAMNED Dogleg. And YES YOU Can use a 6000 series cab on a C10 only thing is use the correct trans/floor cover. Hope this is not too confusing Regards | | | | | Joined: Mar 2004 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 75 | I think I have it now. I know what you mean about the fenders. I have been looking for a set of front ones with the smaller tire flare for three months locally ( around a 100 mile trip ) everything is rotted out. If I could find some I would make a road trip. I think shipping would be a killer but I guess I will have no choice. | | |
