Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Hanks custodian, Wayne67vert, Chip O, greenie-reddy), 115 guests, and 6 robots.
Topics128,291
Posts1,058,585
Members48,492
#147257 06/25/2006 6:48 PM
I just got myself set up on this awesome site that a friend sent me, and had a question that may be a re-run for you folks. I was wondering if any one had the answer to why some 1 1/2 tons have the large opening fenders and others have the same fenders as a pick up. My '41 1 1/2 has the small openings on it, some people have told me this is wrong. I have also heard that the large opening makes it a '46, that GM had to conserve steel after the war. Can any one shed some light on this mystery for me? Thanks!
Hello, & Welcome to the Stovebolt Page. You pretty much answered your own question. Beginning with the 1942 model year, G.M. did indeed cut away metal, from the front fender wheel opening line, to conserve metal. Your '41 is correct, in having the beefier(more metal) front fenders.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Thanks alot!
R and G,
Take good care of your 1/2 ton style fenders. Even poor steel ones are getting hard to come by. If yours are in bad shape, an old school metal worker in a body shop might be able to salvage them. All four corners on my truck are heading for the body shop later this week. I did an OK job pounding out some dents and mending tears, but I need a pro to finish them off.
Good luck on your truck...
The most common question asked on here...Do you have any pictures of your truck?
I have found out through trial and error that there were 3 sizes of fenders used on 46 conventional cab trucks. One size for 1/2 and 3/4 ton. One size for 1 tons that were also used on some 1 1/2 ton trucks, maybe just 46 models ? And the 1 1/2 ton and larger fenders. A look through the gallery shows the two sizes of fenders used on the 1 1/2 tons.
There are 3 size fenders, Look in a Chevy parts book. 1/2 +3/4 ton use one size, 1- 1 1/2 ton use the next size, and then 1 1/2 ton with HD front axel and 2 ton use the large opening fenders.
I had always had the impression (thought I had read it somewhere) that that the larger openings and rounded off corners on the big trucks was to provide clearance for the larger tires when turning corners.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Check out, 75 Years Of Chevrolet, by George H. Dammann. Page 164, last paragraph, right hand column. Tells about the fenders. Reads as follows, "As could be expected, the military, & war-related industries were gobbling up the truck line just about as fast as Chevrolet could turn them out. The only changes made to the 1942 truck line, except for taking away all chrome articles, was the cutting away of the front fender line to conserve metal, and doing away with the floor mat, to conserve rubber".
Spanky Hardy
1950 GMC 250 1-Ton
