| | | Forums66 Topics128,186 Posts1,057,315 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 39 Member | | Member Joined: Jun 2006 Posts: 39 | After successfully driving Cloey (1942 1.5 ton 4x4) for 7 hours straight yesterday, I stopped to get fuel and when I started to take off the front left wheel was locked up. It rolls backwards fine but not forward. I jacked up the axle; the drum was hot as a pistol so I removed the clips in the backplate to expose the brake shoe adjustment mechanisms and adjusted the shoes inwards, thinking the return spring maybe broken..... that's not it, you can roll the wheel in reverse (and that motion transfers to the front driveline OK so it's not the differential or axle) but it will not move forward. There's no rattles, crunching, nothing. The bearing housing was just warm and I heard no telltale wheel bearing noise..... Any Ideas? | | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | How does it act when it cools? I had mine over adjusted once and they tightened up with the heat of driving. Is there any gear lube in that wheel? Scott | | | | | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | do you hear a slight drag in reverse? sounds like a lining come off and is wedging one way.....
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
| | | | | Joined: Jun 2006 Posts: 39 Member | | Member Joined: Jun 2006 Posts: 39 | We're tearing into this in the next few days.... I'll report back. | | |
