5 members (Otto Skorzeny, Bill Hanlon, Shaffer's1950, KEVINSKI, 1 invisible), 327 guests, and 0 robots.
Topics128,101
Posts1,056,180
Members48,436
#147048 06/03/2006 1:23 AM
Apprentice
Apprentice
Trying to remove the rear brake drums on my 46 1 1/2 ton. Any tips on how to get it off. I removed the axle part but stuck on the drum. The book talks about a puller?
Back the brake adjusters off all the way and make sure the e brake cables are not tight. Remove the axle nut and outer wheel bearing. This should have the hub drum assembly loose fron the houseing, this comes off in one peace. If the adjusters are stuck use some pb blaster on them and take your time they will give it up don't force any thing or you will buying parts.
Take the drum and hub off together. Some separate and some don't,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
